Need some towing info
Hello,
I own a 2009 honda accord exl v6 model auto. I'm trying to gather some info in which if I can tow with this vehicle. It going to be towing a motorcycle weighing less then 500 lbs. Long distance (8 hr drive) probably 2-3 time a year. I would be using a utility trailer, transmission cooler and a couple of cargo items. I know this car has a towing capacity of 1000lbs per manual. Did some research but none quite answer my question. Would my transmission be in jeopardy? Is this possible? If you have done something similar to this please give me your thoughts. Thank you.
Re: Need some towing info
I am not certain of the towing capability stated in the owners manual. If it is specified, use the rear axle weight, or 1/2 of the total vehicle capacity (For most cars in this class this is around 850lbs, see the door jamb). This would mean around 425lbs tongue weight.
An aftermarket transmission cooler will help prevent premature damage to the unit, the problem is there is no way to disable the torque converter clutch in this model other than D3, which is the item I would be most concerned about. During towing D3 should be used to prevent TCC wear.
Unfortunately just because you can stick a hitch on a car doesn't mean you should tow with it. Even though you may get by with what you have, I can tell you that it will cause damage to the converter. I've seen plenty of 1991 Civic's with hitches, it doesn't mean you should do it.
If I was in your shoes, and had to move something, do so at a reduced speed (50-55mph). I would not make it a repeated process, you WILL cause damage eventually. It is in times like these that a rental truck is warranted. I've rebuilt a lot of transmissions, and rear axles, and most of them relate to excessive towing incidents or plain overloading of the vehicle. Take my advice as you wish.
RhombeusGSR
07-10-2006 10:07 PM
ProjectBeater
10-07-2002 11:22 AM
