Transmission & Drivetrain Gearboxes, Differentials, Clutches
A little help? : Starter spins freely
Old 07-07-2010, 05:09 PM
strictly german's Avatar
Default A little help? : Starter spins freely
I just installed a competition clutch stage 2 clutch/flywheel combo, and got it all back together. I turn the key, and it sounds like the starter spins freely. I just get a loud windy sound like a motor under no load. The starter is installed correctly, and flush with the bellhousing. Any ideas? is it possible to install a starter on Hondas and not have the starter engaged to the flywheel? Its just strange...
Old 07-07-2010, 06:18 PM
98exn20's Avatar
Default Re: A little help? : Starter spins freely
Is it possible to install the flywheel backwards? I dont know if it will even go in backwards, but you may have to check that, unless someone has a better suggestion.
Old 07-08-2010, 02:24 AM
I wont say its impossible although you'd have to be pretty good... haha. Its def in the right way. Thanks though!
Old 07-08-2010, 09:38 PM
95skunkedgsr's Avatar
pull starter out again and look at the teeth on it and then look at the teeth on the flywheel , dose anything look funny ?
Old 07-09-2010, 10:36 PM
caiboR's Avatar
check the teeth ring on the flywheel to see if it's loose. The flywheel maybe a 2 piece flywheel where pressured screws are holding them together...
Old 07-09-2010, 10:45 PM
bluejcivic's Avatar
maybe your starter solenoid isn't engaging in? pull your starter out and use a pair of jumpers to make it turn over and check if its popping out.
HerbNRacer
08-07-2015 11:58 AM
Andyb22g
11-22-2004 03:30 PM
92lsr
01-17-2004 09:27 AM
typeRicer hater
01-09-2003 12:56 AM
apexii
02-19-2002 12:57 PM
Quick Reply: A little help? : Starter spins freely
