ITR vs. GSR clutch?
ITR vs. GSR clutch?
What is the difference between an ITR and GSR clutch set? Does the ITR pressure plate have a higher clamp load? Will an ITR clutch kit bolt up to a 97 GSR block? Difference in disc material?
If they are the same, why do auto retail parts stores have different clutch kits for the GSR and ITR?
Re: ITR vs. GSR clutch? (ruffrhyder)
clutch discs are the same, pressure plates are different. All fit the same in any combination. I assume the clamping force is higher on the type r.
danny98r
03-05-2004 12:05 PM
