HELP PLease!!!! Axle or tranny???
well i just put this in and having issuse.....not sure if its the tranny or axle. Axle was fine before new (used) tranny was installed.. Its a JDM GSR with LSD. I noticwe that it only does it when im turning. I've attach a link to youtube. As you will notice that i cherp going foward with no problem but when i go foward with the wheels turned to the right it CLICKS and Grinds like hell, feels like it getting jamed. So what might this be please help......
http://www.youtube.com/watch?v=5tSLVoGbeuk
someone got to know somthing....here are my thought if the tranny was bad itr wouldnt just do it while im turning right?? that would mean its the axle correct?
Re: HELP PLease!!!! Axle or tranny??? (laziebun)
Sounds like the cv joint change the axle they're cheap, and if the noise is still there
it's probably the diff. good luck
Daisy... Daisy...
Is it the stock helical LSD?
Have you put the car in the air and attempeted to make the noise by rotating the wheels by hand?
Re: HELP PLease!!!! Axle or tranny??? (Dogginator)
its stock lsd and yes i put it in the air and no noise...i have it in third going 25mph and turning the wheel no noise. onloy does it with load.
Daisy... Daisy...
Yes. If it was the differential, it would make the noise all of the time when turning, shortly before it simply seized.
Re: (laziebun)
put both front wheels in the air and have 1 person hold one side and another try to turn the other side by hand, that'll usually show any dif problems. But that really sounds like a bad axle, maybe you pulled the cv joints apart?
Daisy... Daisy...
Re: (laziebun)
You can reduild them. The procedure is in the Helm manual.
If there is slop, you should be able to feel it. Raise one front wheel at a time, leave the transmission in gear, and rotate the raised wheel back and forth to observe any slop and where it is occuring.
Re: (laziebun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laziebun »</TD></TR><TR><TD CLASS="quote">how is it possible to pull the cv joint apart? isnt that inpossible to do?</TD></TR></TABLE>when your jerking and tugging on the axle to get it out to change the trans,did you pull on the end or pop it out at the trans? there is 3 bearings and slides inside of the cv joint if you pulled on the wrong part of it and the slides got jammed and then you forced it back into the hub< thats what I mean about pulling it apart...do you notice the steering wheel jumping back and forth when your turning?
Re: (srmofo)
Sounds like the same thing that my (we think) factory LSD tranny did when I first drove it
I ended up putting GM Synchromesh additive (2 small bottles) in with my tranny fluid and it stopped
Some LSD's are noisy... some are VERY noisy
Check this link
https://honda-tech.com/zerothread?id=641177
/my helpfulness for '08
Check this link
EK_HATCHBACK
10
11-05-2012 08:24 AM
