Transmission & Drivetrain Gearboxes, Differentials, Clutches
H22A M2B4 LSD unit - will it fit in a USDM H22 Tranny?
Old 10-02-2008, 11:10 AM
pcguy760's Avatar
Default H22A M2B4 LSD unit - will it fit in a USDM H22 Tranny?
Does anyone know if the LSD from a H22A would fit a 99 H22A USDM Tranny?
Old 10-02-2008, 11:17 AM
D Tranny Guru
Mista Bone's Avatar
Default Re: H22A M2B4 LSD unit - will it fit in a USDM H22 Tranny? (pcguy760)
no way!
The LSD is wider and requires a different outer case half.
Old 10-02-2008, 07:06 PM
pcguy760's Avatar
Default Re: H22A M2B4 LSD unit - will it fit in a USDM H22 Tranny? (Mista Bone)
Old 10-02-2008, 11:37 PM
D Tranny Guru
Mista Bone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcguy760 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Quit crying emo boy!!!!
LOL, JFWY.
A local shop/tuner had a JDM LSD tranny, only who he bought it from had to DRIVE the passenger side axle out.....only it cracked the outer casing where the diff bearing was. I was called in to help transplant the LSD.......10 minutes later it is called a no go.
It sucks.
Old 10-03-2008, 09:31 AM
pcguy760's Avatar
Alright I guess its better to just get a complete M2B4 LSD Tranny then...
Old 10-05-2008, 05:24 AM
swarsi's Avatar
Ok so thats a no go but what about this?? Can the internals from a M2B4 transmission be mounted into a USDM M2Y4?? Or any US H22 tranny? Reason i ask is I cracked my bell housing on the M2B4 by the slave cylinder mount. I think I just need a bellhousing????
Old 10-17-2008, 11:24 PM
pcguy760's Avatar
Default Re: H22A M2B4 LSD unit - will it fit in a USDM H22 Tranny? (swarsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swarsi &raquo;</TD></TR><TR><TD CLASS="quote">Ok so thats a no go but what about this?? Can the internals from a M2B4 transmission be mounted into a USDM M2Y4?? Or any US H22 tranny? Reason i ask is I cracked my bell housing on the M2B4 by the slave cylinder mount. I think I just need a bellhousing????</TD></TR></TABLE>
No from what I read, those two are housings are not interchangeable.
Slomies
12-26-2005 06:55 AM
st3alth
11-09-2005 07:12 AM
H22NOSACC
10-05-2004 07:47 PM
mugencl1
04-30-2003 08:12 PM
H22ACiViC
02-02-2002 08:39 AM
Quick Reply: H22A M2B4 LSD unit - will it fit in a USDM H22 Tranny?
