Transmission & Drivetrain Gearboxes, Differentials, Clutches
GSR transmission whine!
Old 02-03-2014, 07:08 PM
thecruzs2007@yahoo.com's Avatar
Default GSR transmission whine!
ok so i just acquired a gsr tranny for a good deal with previous owner claiming it was in good working condition, so my problem is i have an annoying whine in all gears at any speed above 5mph or so. the whine sounds like when I'm going in reverse..i did change both axle seals and shifter seal. i used 2.3 quarts of pennzoil synchromesh. axles are all the way in as well.. my next move will be draining the synchromesh and replacing it with honda mtf.. any ideas? possibly bad bearings?
Old 02-03-2014, 07:47 PM
Runnerdown's Avatar
Default Re: GSR transmission whine!
The fluid change is a waste of money, it's pretty likely something is damaged or installed improperly. Stock transmissions rarely make any whining sounds. Best bet is to pull it apart for an inspection. I find that many used transmissions are sold as mint or perfect and they are really not.
Old 02-04-2014, 05:56 AM
Spiff671's Avatar
Hmmm.. yes, it could be a broken bearing(s). I've encountered that numerous times.
As for the new fluid, I'd just re-use it.. no worries..
I'd definitely open it up and do a thorough inspection on all bearings, gears, clearances, etc. Are you well-versed in the B-series transmissions? I can email the factory service manual to you if need be. Just PM me your email address.
Old 02-04-2014, 06:47 AM
Aquafina's Avatar
It could be many things, it needs to be taken apart and inspected. Don't use Honda MTF.
Most used transmissions sold now need to be rebuilt. The newest B transmission (that wasn't purchased new from the parts department) is 13 years old.
Old 02-11-2014, 05:58 PM
Spiff671's Avatar
I never encountered issues with Honda MTF. Please explain.
Old 02-12-2014, 12:09 PM
Aquafina's Avatar
In short it is too thin and lacks adequate EP additives.
93allmotorcoupe
08-20-2009 07:38 PM
dc2-jdmfoo
02-29-2008 09:28 PM
jumai182
26
05-13-2007 08:55 AM
smooz EK
02-25-2007 03:20 PM
Quick Reply: GSR transmission whine!
