Gsr transmission problem. Car wont move! Please help!
Sorry I'm pretty new to this and need help! ok so first off I built an ls vtec motor with a gsr transmission lsd 5 speed . built was successful. I did a auto to manual conversion on my eg and that went fine as well . now onto the problem. on the day of dyno they started up the motor but couldn't get the clutch to disengage so it wasn't grabbing or moving . it was a worn act stage 2 clutch so it had to be replaced... I got a brand new competition stage 2 clutch to replace it. today it started and everything went fine.it was on the dyno and ready for pick up later. I picked it up and drove 5 miles. then suddenly when releasing from first gear from a dig, I hear a small snap/pop under the shift boot and no longer accelerated . the car went into gear and can hear it click into gear as it does. as I release the clutch gave it some gas nothing... tried statrting from second gear feom a dig and still nothing.. what could be the problem? it's literally a 7 hour old clutch so I hope that's not it. gsr was rebuilt with new synchros . Again, it's going into gear but not moving when I try accelerating ajd ease off the clutch... shift linkage is new type r. new slave master, clutch master, and clutch line are new as well... please and thanks !!
Re: Gsr transmission problem. Car wont move! Please help!
I would double check and make sure that the passenger side axle didn't pop out... sometimes it can look like it is in, but in fact, it is just a bit out... like 3/8" from the case.
suprafly
02-18-2005 04:09 PM
