Engine swapped now gears shift terribly
Hey guys I just did an engine swap for my 98 civic dx its a d16y7 I'm using my same tranny the car was shifting perfectly fine and now its really hard to shift into gears also at low rpm my car barely moves does anybody know what could be the issue
Re: Engine swapped now gears shift terribly
Likely something wrong with your clutch installation. It could be as simple as an improperly bled clutch hydraulic line... but it may be inside the bell housing and will require removing the transmission to diagnose.
I attempted to full out the engine and starting lifted the car off the jacks and it was because I didn't remove my shift linkage I may have bent it and if I did would that cause for my gears to be extremely stiff?
static-x
07-31-2007 09:52 AM
wizzards581
01-24-2002 05:44 AM
