Transmission & Drivetrain Gearboxes, Differentials, Clutches
Clutch pedal leaking & gust of air on disengage
Old 07-12-2016, 02:55 AM
Stonage07's Avatar
Default Clutch pedal leaking {MC leak symptoms?}
I've had the car for a short month now and i havent noticed a problem with the clutch at all, but I checked out a air noise coming from the clutch and it is leaking slightly from the pedal @ the firewall. What can be the cause for a leak starting there? The gust of air is starting to annoy me aswell, lol.. Thanks
Old 07-12-2016, 04:22 AM
Stonage07's Avatar
Default Re: Clutch pedal leaking & gust of air on disengage
I assume the safest method of fixing would be to replace the whole cylinder huh? Meh!
Old 07-14-2016, 06:45 PM
holmesnmanny's Avatar
Normally if it's leaking at the pushrod then the master cylinder is bad. It's best to replace it and the slave at the same time.
Old 07-17-2016, 08:02 AM
Stonage07's Avatar
Yeah I assume so, i have no clue how long the previous owner has been driving with a laeking clutch rod either. Is it dangerous at all? Suspension is first on da list!! The stiffness will break up every goddamn ball joint lol
Old 07-19-2016, 01:17 PM
At some point it's just going to give out completely and not be able to go into gear. That would be dangerous if you pull out in front of someone and can't accelerate, so yes it's dangerous.
Old 01-02-2017, 10:02 AM
Stonage07's Avatar
Let me just put a lighter to this topic once moree!
Now a few months later, the leak and pedal feel seems to be in the same shape as before, hasnt gotten worse.. It still has jerking problems when shifting, and a high clutch engagement in pedal... How much does a Master and Slave cylinder play part in this? I genuinelly CANNOT do a WOT 1st gear pull without being shook around, But in comparison shifting from 2-5th is pretty much flawless, a little jerk but much less obvious momentum {ik}
Doesnt give me a good feeling launching it, and I practically havent done it in a long long time..
Tips are more than appreciated!
backinblue92
05-10-2015 12:37 PM
Valenciabrihh
12-29-2014 05:25 PM
Shyztone1
01-22-2012 03:10 PM
h23darkprelude
11-18-2009 08:34 PM
byronl
05-02-2006 07:53 PM
Quick Reply: Clutch pedal leaking & gust of air on disengage
