CC stage 4 after 4 years
About 300hp with a lsd, what you guys think of it?
Throwout bearing spins normal.
As you can see in the 2nd pic the spring holder (silver metal thats between the black metals) is broken missing a wall, the other ones are bend from spring pressure.
Some paper towel left behind and water from a wipe down
Re: CC stage 4 after 4 years
Yeah first gear engaged really late sometimes, like almost at the end when you let your foot off the pedal. It engaged fine tho. And it wasnt a cold start thing.
The more serious problem is the launch, you can rev it to like 3-4k before dropping the clutch and the engine would go like 3k 4k then drop back to 2k and "restart" the whole gear.
Made me loose some off the line races. I had a fresh CC stage 4 in a different car and it never had that issue.
