Car will not go into gear! need help. - Honda-Tech
Old 06-07-2010, 02:02 AM   #1
dc2long's Avatar
Default Car will not go into gear! need help.
Hey guys, I got gsr and I have been having problems with the clutch/tranny. Sometimes the car will not go into gear when it is on. I thought it was a bad slave cylinder so I changed it but the problem still persist. This doesnt happen all the time though, usually when the car does not go into gear, I pump the clutch really hard about 10-20 times and the gears work again.. other times it wont work at all. And when I get it to work, I cant drive at high past 5k rpm because the car will lose power and the gears get stuck.
Ive bled the fluid plenty of times already and it use to work fine for about a week then the problem comes back, but the problem is getting worse so bleeding wont even help anymore
I dont think there is a leak anywhere because the fluid level is always normal.
I have no idea what the problem could be and its getting really annoying
Im not quite sure what the setup is because this car belongs to my friend.
the only thing i know about it is that its a 6puck clutch with an aftermarket pressure plate. It grabs VERY hard.
PLEASE HELP ME!
dc2long is offline   Reply With Quote
Old 06-07-2010, 09:10 AM   #2
Quada's Avatar
Default Re: Car will not go into gear! need help.
more information? Do you mean that the shifter physically cannot go into the gear or you have the shifter in gear but the car will not move upon releasing the clutch?
Quada is offline   Reply With Quote
Old 06-07-2010, 01:53 PM   #3
dc2long's Avatar
Quote:
Sorry, Yeah i meant the shifter will not go into gear at all when the car is on. If i turn the car off, I can put it in gear and if i start it in gear the car will move as if the clutch engaged.
Old 06-07-2010, 01:57 PM   #4
dc2long's Avatar
Also there is always pressure on the clutch so I'm thinking the Master cylinder is still good?
Old 06-07-2010, 02:16 PM   #5
dc2long's Avatar
car will not go into gear anymore even after pumping the clutch for 15 minutes!
Old 06-07-2010, 10:55 PM   #6
PMK
PMK's Avatar
your whole clutch setup is ****ed. pressure plate, clutch disc and flywheel might be ****ed up. most likely your throwout bearing splitted into 2 pieces. happened to me. sorry buddy hope this helps.
PMK is offline   Reply With Quote
Old 06-07-2010, 10:56 PM   #7
Quada's Avatar
dc2long, have you ever replaced a clutch before?
Old 06-08-2010, 03:32 AM   #8
PMK
PMK's Avatar
yep. i had the same problem as you but i couldnt get pass 3k-4k. take off your transmission and see what happenend.
my friend is soon gonna have the same problem too. he has a stage 4 clutch master setup and last night was bad.
Old 06-09-2010, 04:44 PM   #9
dc2long's Avatar
to be honest i have no idea is wrong with the car anymore. At times it works perfectly and revs high with no problems, other times the car wont go into gear at all during start up. If my clutch is really messed up, would it play games with me like this?
For example,
12:00pm - I go outside to start the car to go grab a bite, Car starts but will not go into gear. So I decide to just pump the clutch a few times with the car on and off, Still does not go into gear. So I give up.
12:30pm - I decide to give it another try because I'm getting really hungry, Turn the car on and everything works perfectly.
1:30pm - Finish eating and go outside to start the car, Car will not go into gear at all. So I leave the car there and go home with a friend.
6:00pm - Come back for the car and still does not go into gear. I try pumping the clutch and everything and still does not go into gear. So I wait around for about 30 minutes, Try it again and still does not want to go in gear. I leave the car overnight.
9:00am next morning - I come back for the car, Still does not want to work.
12:00pm - Come back and the car works perfectly.
I feel like this car only wants to be driven when it wants to..
Any other ideas?
can it really be the clutch? works perfectly at times.
Clutch master cylinder?
Old 06-09-2010, 06:00 PM   #10
Quada's Avatar
do you notice anything with the outside temperature as these things happen?
Old 06-09-2010, 10:34 PM   #11
dc2long's Avatar
I thought about the temperature but sometimes it works 15 minutes after not working. I think it works more often when the temperature is cooler.
Old 06-11-2010, 11:49 AM   #12
Who the fack changed my title?!
sh!ft's Avatar
its an internal problem
sh!ft is offline   Reply With Quote
94 Honda Accord MT Won't Engage Gears grimsguy Honda Accord (1990 - 2002) 11 06-29-2013 01:29 AM
Clutch problem help!! evade_07 Honda / Acura 13 12-13-2008 11:15 PM
HARD TO GET INTO GEAR!!!!!!!!!!!!!!!!!!!!!!!!!!!! integracura Acura Integra 10 04-18-2007 12:18 PM
Mushy Clutch and Hard to Shift 13DevilsCamry Honda Civic / Del Sol (1992 - 2000) 6 04-08-2005 08:53 AM
Tranny woes. Help! Jonathan_ED3 Honda Civic / Del Sol (1992 - 2000) 6 03-14-2003 12:23 AM
Tags
bad, car, ccylinder, civic, clutch, engaged, gear, gears, honda, integra, move, put, rsx, slave, tech, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
