Transmission & Drivetrain Gearboxes, Differentials, Clutches
Can you identify this clutch type LSD?
Old 01-19-2010, 11:32 AM
New User
ULTRA_ORANGE's Avatar
Icon6 Can you identify this clutch type LSD?
Its from a B-series, cable operated clutch. It came as a sprare tranny with the 91 civic I bought.
Serial Number of bearings; NTN, JAPAN EH, TMB208CZ, and TMB208CX1
As I can't find the maker, I can't find a rebuilt kit. Clutches are paper thin, no more grooves on them.
I need to rebuilt this!
Thanks!
Old 01-22-2010, 12:58 PM
New User
Default Re: Can you identify this clutch type LSD?
Do you need picts of the internal parts?
Old 01-31-2010, 07:59 PM
New User
ttt
Old 02-02-2010, 12:11 PM
jdmoutlaw's Avatar
That is not the normal LSD that comes in a cable case. Looks to be some kind of after market. The clutch type found in a cable trans has the ring gear made on to and is not replaceable. When you take out what you would first think to be ring gear bolts your actully splitting the lsd.
I know I was not much help to you maybe somebody will be. Atleast you know to look at after market companys
Old 02-07-2010, 06:51 PM
New User
264 readers, no answer...
Old 02-28-2010, 06:59 PM
New User
ttt
Old 04-11-2010, 10:09 PM
jdmkha's Avatar
OMG!!!! I have that exact same looking clutch LSD!! I am tring to find someone who knows what the hell kind of LSD this is, so I can replace mine. My **** broke into hundreds of pieces. Now I cant drive my car becuse of this ****... bought the b16a engine n trans off a friend, the engine has b16a stamped on it but the trans is ****in blank.. DID U EVER GET THE ANSWER FROM SOME ONE ELSE PLEASE HELP ME. PS dont mean to thread jack,but I am in serious need of help here.
Old 04-11-2010, 10:10 PM
jdmkha's Avatar
MY RING GEAR HAS 66 teeth mated with 15 teeth counter....
Old 04-12-2010, 08:37 PM
ramco's Avatar
there are people on here that can answer your question, but most don't want to bother I have found. Actually this thread answered a question I have asked several times on different posts in the past year. I had a LSD with non removable/non replaceable ring gear. couldn't find out what it came in or who made it. I was told by the "experts" that they have never heard of such a thing. I thought I must be loosing my mind, I bought it out of a broken hydro b series tranny and took it to a "friend" named Aidan at 5150 racing, to put into an LS box...Never saw it again. a year later I got my tranny case back, all filled with junk parts, including a different LSD(Viscous) with a broken ring gear on it which can't be replaced in the USA. Even my case was wrecked by the "builder" and I had to buy everything over again. Sorry for the rant, but finally I now see there is such a thing as as a non removable ring gear type diff. Anybody know what type; Viscous, Helical, or plate type?
66 x 15 tooth is 4.40 ratio, came in most B trannys except LS.
Old 04-14-2010, 07:35 PM
jdmkha's Avatar
NO MY RING GEAR COMES OFF. I JUST CANT FIND SNY ONE WHO WILL TELL ME WHAT KIND OFF LSD TO PURCHASE... PLEASE HELP ME....... SO ONE TOLD ME THAT IT WAS A GSR DIFF BUT WHEN I BOUGHT THE GSR DIFF THE RING GEAR WOULDNT FIT OVER TOP OF IT. BUT IT DOES BOLT ON THE OPPOSITE WAY. WILL IT WORK?????? BY THE WAY ITS 66 TEETH RING GEAR 15 COUNTER & A 10 BOLT PATERN. IT IS ALSO A HYDRO TRANNY I JUST DONT KNOW IF ITS B16 OR B18.. DOES THE B16 HAVE A 10 BOLT PATERN ????????? I NEED HELP BAD THIS IS MY DD PLEASE HELP ME......
Old 04-14-2010, 09:21 PM
ramco's Avatar
there are two 10 bolt diffs for Bs. measure ring ID and carrier OD!!! If you don't have calipers, wrap a piece of paper around, mark it, flatten back out, measure the length and divide by 3.1415 to get diameter. LMK. Nobody can help you without some information. we don't have crystal *****.
Old 04-15-2010, 07:59 PM
jdmkha's Avatar
WHAT ARE THE TWO DIFFERENT DIFFS USED 1 FOR B16 AND I FOR B18?
Old 04-15-2010, 08:06 PM
jdmkha's Avatar
THE REASON WHY I ASK IS BC MY RING GEAR WONT FIT ON THE GSR MEANING IT CAN ONLY THEN FIT A B16 ___---- DOES THAT MAKE ANY SENSE?
Old 04-15-2010, 10:53 PM
MFactory's Avatar
If the ring gear is part of the LSD (ie when you disassemble the differential), you will see teeth along the ID of the ring gear. This is a Viscous LSD. No B-Series came with an oem Plate LSD. You have three options:
- Open Diff
- Viscous Diff
- Helical Diff (Type-R Only)
If you have the Viscous Diff, then you are out of luck. To change anything requires changing the entire differential assembly i.e Diff, Ring Gear, Pinion. The parts are not interchangeable with anything else
The LSD posted in the 1st post, that is a 1.0way Plate LSD. This is an aftermarket unit, not oem.
Old 04-18-2010, 11:23 PM
jdmkha's Avatar
Nope no id teeth on my ring gear,however i counted the reeth on my ring with a total of 66 on the ring 15 teeth on the counter. just not sure if its gsr or a b16 diff i need. i tried to put it onto a obx diff but the ring gear wont go over it the diff is too fat but it willl bolt right the other way around will it work that way??? or should i be buying a b16 diff ??? not realy sure so damn confusing
Old 04-22-2010, 08:17 AM
Go Tigers!
Bense's Avatar
This is a free forum, we're all volunteers here. We're not obligated to volunteer our knowledge and do research for you.
Old 04-22-2010, 11:15 AM
supra-maria's Avatar
ttttttttttttt
Old 04-29-2010, 09:53 PM
cloneme311's Avatar
i have the same diff. blew it to pieces. but anyway i have all the plates they still have lines in them, just pm me if you want them.
Old 10-21-2010, 03:41 PM
jdmdb8r's Avatar
bump
Old 02-04-2016, 01:55 PM
b18vtecboi's Avatar
I hate to be the one bringing back up a 6 year old thread..... but anybody figure out what diff. this is posted in the original post. I was given a transmission with this same LSD diff. inside and I am also trying to figure out who makes it.
Old 07-05-2016, 03:46 AM
Go Tigers!
Bense's Avatar
Might help if he didn't take the pics with a potato camera. But the post that MFactory made is correct. OP appears to have acquired a transmission that the previous owner (likely in Japan) has installed an aftermarket LSD. With this being a Cable B Trans, so that's what? 25 years old? Good luck figuring this one out. OP would have to dissect the thing and get much better pictures.
- Open Diff
- Viscous Diff
Strange how I keep finding old threads that I've been in when I search for differential carrier bearing part numbers.
ef9tuner
12-03-2011 11:29 PM
tooslohatch
12-12-2007 02:04 PM
KFBhonda
03-04-2005 02:48 PM
krazie1
08-11-2004 02:19 PM
teggy007
03-17-2003 01:17 PM
Quick Reply: Can you identify this clutch type LSD?
