Transmission & Drivetrain Gearboxes, Differentials, Clutches
b16 vs gsr vs ls vs type r transmission
Old 05-29-2014, 08:16 PM
big.turbo.daddy's Avatar
Default b16 vs gsr vs ls vs type r transmission
Whats the best transmission to run on a 450 hp civic cause right now I got an ls and the gears are longer than all the others. I am planning to built the transmission so I was wondering will it make a a difference if I choose the gsr or type r tranny and built over the ls?
Old 05-29-2014, 08:24 PM
Emeraldbomber's Avatar
B16 is the shortest and easier to find. The jdm type R is LSD and has a 4.7 FD. What's the purpose of the car?
Old 05-29-2014, 11:33 PM
Default Re: b16 vs gsr vs ls vs type r transmission
To race it at the drag strip and just have fun with it while I have the car
Old 05-30-2014, 05:55 AM
KevinT707's Avatar
From shortest-longest gear ratio: LS, GSR, Type-R, B16.
I wouldn't be able to tell you which trans would be best but in my opinion I don't feel that even the LS trans would be bad because of the longer gears allowing you to stay in your power band longer. With that power you'll be revving through gears so fast anyway, plus it's cheaper.
Now, if this was an N/A setup then I'd so go with the shorter ratio trans.
Old 05-30-2014, 05:59 AM
Your going to want the shortest trans you can get while maintaining traction for a 1/4 pass.
Old 05-30-2014, 10:37 AM
Thats what I said but my friends always tell me to go gsr or even typr r if I can find one. Thats why I had this question
Old 05-30-2014, 10:40 AM
So like a b16 be good to have on a 1/4 mile
Old 05-30-2014, 10:21 PM
HYREV2NR's Avatar
B16 and USDM Type R trans are geared the same minus the R trans has LSD. Both have the 4.40 F/D as well as the the GS-R gear box. The 94-01 GS-R has a slightly taller 2nd through 5th than the B16 or ITR. IIRC some of the boosted guys years ago were using B16/ITR 1-5 gear set with the LS 4.26 F/D.
Old 05-31-2014, 03:24 PM
Aquafina's Avatar
GSR 1/2, B16 3/4/5, MFactory 4.05 FD and helical LSD.
Old 06-02-2014, 07:32 PM
D Tranny Guru
Mista Bone's Avatar
If you like shifting into 5th gear at 1000 foot maybe....
Old 06-02-2014, 08:33 PM
Didn't really think of that. Good call. This is why I don't dragrace.
MR.johnson
01-04-2012 09:00 PM
MrMug3n
13
04-15-2008 03:25 PM
egjdm1
03-04-2008 07:43 PM
Jdmsolutions
06-28-2006 05:25 AM
jdmkrazie
01-06-2004 03:07 PM
Quick Reply: b16 vs gsr vs ls vs type r transmission
