2007 civic SI - Hard to get into gears - Honda-Tech
Old 02-08-2017, 04:01 PM   #1
Default 2007 civic SI - Hard to get into gears
For a few months I've been having trouble getting my car into any of the gears. Clutch is in all the way, but the shifter fights me going into gear. It's alot worse the colder it is. Anything below freezing temperatures. And sometimes it's bad just over freezing. Sometimes after around 30 mins of driving it seems to either completely disappear or it will get marginally better. I only noticed it at the beginning of winter when the temperatures dropped. Also, I can feel the car start trying to move forward when I'm at a stop trying to get it into first, as if the clutch isn't engaged all the way. And it doesn't grind when I do get it to it into gear (although it has happened a couple times *shudder*) Any ideas what this could be? I'm not a mechanic by any means but I do have a small amount of automotive knowledge. Just enough to get me into trouble haha. Thanks for any help.
Mrsweet is offline   Reply With Quote
Old 02-09-2017, 05:14 AM   #2
Seagull Management
94EG8's Avatar
Default Re: 2007 civic SI - Hard to get into gears
Clutch master and/or slave cylinder is most likely bad. Check the fluid level in the resorvoir, check for fluid leaking on the inside of the firewall as well.
94EG8 is offline   Reply With Quote
Old 02-09-2017, 02:26 PM   #3
Would that cause it to be worse in the freezing temperatures? On my way home today it was 7 degrees Celsius (Warmed up a bit) and it shifted great. It was just tough to get into gear for the first two shifts.
The fluid level looked fine and I didn't see any leaks. I'll have better look when I get home though. I've also noticed the pedal is a tiny bit soft after its been sitting for a little but. Thanks for any help/insight.
Old 02-09-2017, 06:48 PM   #4
Seagull Management
94EG8's Avatar
It could. If the pedal feels a bit soft that's a really good indicator that either the master are slave are failing. If you put it in neutral and pump the clutch pedal a few times does pedal feel and shifting improve?
Old 02-10-2017, 03:12 PM   #5
It does get a little bit better. It's still not great though. I'll look into replacing those this weekend.
Old 02-13-2017, 01:05 PM   #6
Just thought I'd update this post. I bled the clutch line yesterday. What came out was very black. I flushed it all the way through until it was clean fluid coming out. It hasn't gone below freezing yet, but so far it feels much better. No issue getting it into gear at all. So Hopefully that solved it. If not, my next step will be to replace the master and slave cylinders. Thanks for the help
drain water from block sgull Honda Accord (1990 - 2002) 3 11-27-2012 07:01 AM
pass door lock freezes up everytime when temp hits below Rayz_Si Honda Civic / Del Sol (1992 - 2000) 9 02-17-2008 02:31 PM
1993 del sol shifting problem when cold. fastrc2 Honda Civic / Del Sol (1992 - 2000) 9 12-08-2007 10:14 AM
Washer fluid freezing up. Suggestions on what brand would help? Vindicator9000 Honda Civic / Del Sol (1992 - 2000) 16 11-27-2006 01:41 PM
Fuse keeps blowing tpelley Honda Civic / Del Sol (1992 - 2000) 2 11-17-2004 08:57 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
