2000 Acura TL Code po740! HELP!
I just bought a 00 TL with 152k miles last month. about two weeks into it the torque converter supposedly went bad and shot metal particles into the trans...according to Honda. Long story short the broker I bought it from sent me to the shop he uses to get it rebuilt and a new converter installed at a really good price. I know you get what you pay for, and I am kicking myself in the rear right now...but financially using the guy I bought it from and paying half of the repair at $550 was alot better than paying $3100. Anyways two to three weeks later I am having hard shift problems as well as a little slippage between 2nd and 3rd, and running a low 2000rpms at 75-80mph which used to run high 1000's. went to Autozone today to have the codes ran and it pulled two codes, one of which I a not too concerned about at the moment. one po131 bank 1 sensor 1 o2 and this po740 transaxle lockup clutch system malfunction. I have searched for the last 2 hours with alot of results all saying the trans has to be replaced or rebuilt, but I have maybe 1k miles on my rebuild! it still has roughly 10k miles left under warranty, but my question is what exactly do you guys think is going on here? Is this repair going to be covered or am I most likely going to be out of pocket for this? I love this car and its had 2 owners with no accidents, seats are flawless and the body is straight...so I really want to drive it until it quits and replace the power train and drive it for another 100k miles or more. any help would be greatly appreciated.
Re: 2000 Acura TL Code po740! HELP!
Anybody? I am trying to get some answers before I take it back to the shop. I don't want to have someone just throw parts at it. Even Honda/Acura don't know, their system says replace transmission...but it was just rebuilt.
MM Gruppe B
These years of transmissions had a few issues, most can be fixed at rebuild, but of whomever rebuilt it is not well educated with Honda ATs or just slaps clutch packs into the old trans, it will fail again.
If the TC overheated it is most likely from an overshooting PRV. Fluid flow stops going through the cooler, the trans cooks, and the TCC drags which causes further overheating and wear.
Check out the links under 'more resorces' on the left side of the Sonnax page...
Honda, Acura 4-Speed, 3-Shaft - Sonnax
coleman12
08-10-2013 08:16 PM
coleman12
Transmission & Drivetrain
11
07-20-2013 07:06 AM
stoneyb245
12-12-2006 07:35 PM
