1995 Honda accord d4 light not working at all. And has no power in d4 - Honda-Tech
Old 05-04-2016, 09:07 PM   #1
Default 1995 Honda accord d4 light not working at all. And has no power in d4
Was working fine but I took out the ECU fuse to reset cel after replacing vss. I lost the fuse but I tried replacing and it started doing this. I put in d4 to drive and it just revs but doesn't actually move. It automatic , I can drive by manually shifting but it starts smoking from transmission area. Need help ASAP . do i just get all new fuses ?
VtecGang is offline   Reply With Quote
Old 03-10-2017, 09:14 PM   #2
Default Re: 1995 Honda accord d4 light not working at all. And has no power in d4
I assume all fuses are in place .... if you have smoke from the transmission .. this is serious .. could be no oil inside transmission ... and finally your transmission is toast. Check for leaks beneath your car ...... look for engine and transmission oil leakage. Have your transmission checked ASAP.
amerc is offline   Reply With Quote
91 Accord Power Windows Fuse Sepulveda87 Honda Accord (1990 - 2002) 1 05-01-2015 04:53 AM
1996 Civic wiper problem. possible fuse box issue? lowandloud Honda Civic / Del Sol (1992 - 2000) 3 02-12-2012 06:06 PM
Condenser Fuse Blowing, no A/C demiseraph Honda Civic / Del Sol (1992 - 2000) 7 08-05-2011 05:12 PM
I KEEP BLOWING OUT THE SAME FUSE. PLEASE HELP!! dc2_build Acura Integra 2 12-19-2009 08:50 AM
Fixed lighting problem but now burning smell coupedup Honda Civic / Del Sol (1992 - 2000) 3 02-16-2006 10:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
