02 EP3 K20 Clutch System Issues - Honda-Tech
Old 02-26-2017, 06:28 PM   #1
CivicSiEP3Hatch's Avatar
Icon4 02 EP3 K20 Clutch System Issues
I recently purchased a 02 civic si k20a3 hatch.
I replaced the slave cylinder hoping to solve my issue and no luck.
When i start the car in any gear it is stuck in that gear, if i start it in neutral and i push the clutch in and try to shift into gear it won't engage, it grinds when you start to put it gear. Need help with solving issue.
CivicSiEP3Hatch is offline   Reply With Quote
Old 02-27-2017, 07:23 AM   #2
Aquafina's Avatar
Default Re: 02 EP3 K20 Clutch System Issues
What shape is the master cylinder in?
Aquafina is offline   Reply With Quote
98 Civic won't shift to 1st/2nd with engine on but does with engine off Stock Car Honda Civic / Del Sol (1992 - 2000) 32 01-03-2017 04:16 PM
Starter whine after Fidanza Flywheel install (solved) HerbNRacer Honda Civic / Del Sol (1992 - 2000) 9 08-07-2015 11:58 AM
1994 Honda Accord won't start. Pjathy Honda Accord (1990 - 2002) 1 07-22-2015 10:19 PM
Tapping noise when in 1st-3rd gears stacdizzle Honda Civic (2001 - 2005) 0 06-22-2015 12:56 PM
1994 Honda Accord, f22b2 clutch issue. Brandoncd5 Honda Accord (1990 - 2002) 0 05-31-2015 09:24 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
