Garage Cleanout (Killeen)
Kpjo4's garage cleanout (updated)
K24/K20 obx 4-2-1 Header never used $60
Civic/Integra Upper front strut bar, one of the fancier thicker ebay types $15
B18 ls long block, comes with intake manifold, exhaust manifold, fuel injectors and railing, alternator, most of the sensors, hondata intake manifold gasket. $500
Civic 92-95 passenger door window (hatch/coupe) $20
Rebuilt B series obd 2 non vtec distributor, works fine $40
Civic coupe 06-11 megan exhaust (non si, R18), cheap due to a mid pipe had a hole that was rewelded closed (works fine) $120
New used civic/integra ebay turbo downpipe garret 5 bolt flange. $30
Integra front lca with 22mm sway bar fitted with polyurethane endlinks, amazing upgrade for civics without front sway bars. $120
Window welded b series motor mounts, stiffer than polyurethane inserts mounts. Have various mounts for civics and integras or b series. Message me for details and prices.
Never used b series F1Racing stage 2 clutch kit, carbon kevlar clutch with aluminum lightweight flywheel 9lbs, heavy duty pressure plate, pilot bearing, and throwout bearing (all parts never used) $150
Black Benen Tow hook set, great condition $30
B series shift linkages, fits 92-01 b series swaps or chassis, integras civics $40
B series manual halfshaft (intermediate shaft) $30
Civic 92-95 coupe/hatchback passenger (right side) turn signal, new $10
Accord ex 03-07 factory sway bar $10
Accord 03-05 coupe foglights with bulbs, good condition. $10
Torque damper 92-00 B series $15
Honda/acura testpipe $30
Wastegate external ebay 35/38mm 6-7psi spring $30
B18a/b or b20, arp head studs, have 5k miles on them, $25
GM F body, 2 abs style transam wheels, 16x8 5x120 or 5x4.75" (comes with two tires and one needs replacing. $50
E36 factory headlights, comes with bulbs (has sun damage) $40
N54b30 BMW factory downpipes came off an E92 $100
E36 M42b18 longblock with everything $300, runs well.
E36 smallcase 3.45 ratio 100% lockup (beast welded) $100
E46 M3 S54b32 oilpan with gasket $200
E92 Cracked Carbon Fiber hood ViS M3 style, great fitment still latches close, Could be great for extra carbon fiber weaver or repair job. $100
Garrett T3 nissan ceramic wheel turbocharger from a RB $50
Message me anything for info or pics. text me at 254.247.4424
(sold) B18 ls tranny hydro, good synchros, no grinds, no pop outs, and no slips
(sold) B series manual T/L rear motor mount bracket from an EG
(sold) P75 obd 1 manual transmission ecu
(sold) B18a/b or b20 Used brian crower titanium springs and retainers 5k miles 280 advanced and 11.94mm lift turbo cams. (less valve overlap than factory)
FullThrottleNYC
Performance
44
07-15-2009 01:01 PM
1QwIkEf
Mid-Atlantic (Sales)
04-16-2009 11:17 PM
Suck my DX
01-02-2009 03:29 AM
