fs: 00 civic em1 si w/98 spec itr swap gsr tranny
Im looking to maybe sell my baby! she is my daily driver. I'm located about 20 miles north of Corpus Christi, Texas.
body has 192,000 miles and swap has about 50,000 miles
jdm 98 spec integra type r b18c long block straight from jdmenginescorp.com
usdm 96 gsr transmission
energy suspension motor mount inserts
skunk2 pro series intake manifold
professional products 65mm throttle body
coolant throttle body bypass
ct engineering icebox intake
custom jake intake elbow made from cxracing intake
k&n coupler
ct engineering drop in filter with velocity stack
plm toda replica header w/integra type r header bracket
aem tru power steering pulley
ngk iridium plugs
walbro 255 fuel pump
stock injectors
blox fuel pressure regulator
blox fuel pressure gauge now installed
p28 phearable.net chipped ecu
obd1 to obd2b ecu jumper harness
jared street tuned chip
5400 vtec kick in
5000 rpm launch control
8250 rpm check engine shift light
act prolite flywheel
stage 2 pressure plate
act stage 2 clutch disc
stainless steel clutch line
b&m short throw shifter
energy suspension shifter bushings
civic type r shift boot
koni yellow adjustable struts
skunk2 lowering springs
blox upper control arm front camber kit
wicked tuning rear camber kit
2.5" hi flow catalytic converter
apexi exhaust piping
hks hi power ti tip axle back mandrel bent
15x8 +25 enkei 92s in black with polished lip
update: as of 6/22/12 New tires just installed and a fresh alignment......nitto neogen 205/50/15s all around with warranty from discount tires and the alignment was done at firestone last week.
front and rear fender roll done with eastwood fender roller the right way
pioneer head unit ipod usb ready
10" sub and amp
dc sports rear strut tower bar
morimoto mini h1 retrofit projectors
ac works, powersteering works, sunroof works, cruise control works also. no cels! about 10,000 miles on motor since the swap but it had around 40k before i installed it.
bads: driver side window is unplugged do to coming off track. normal small scratches and dings from daily driving.....rocks always get kicked up around here.
i think this is everything
Getting rid of it fast now ebay style: http://cgi.ebay.com/ebaymotors/?cmd=...%3AMESELX%3AIT
Starting bid $4,000 no reserve!
text only 361-288-6058 or p.m. me
k&n coupler
ngk iridium plugs
stock injectors
5400 vtec kick in
10" sub and amp
Re: fs: 00 civic em1 si w/98 spec itr swap gsr tranny
i bought the civic abot 4 years ago with that bumper. i dont know the reason why it was on there but i didnt care. it was in too good condition to pass up. the title is clean, clear, in my hand, and in my name.
I will not be ending the listing on ebay. People have said they would come down and see the civic and buy it and have not even attempted to come see it. It will sell for sure on ebay.
wasanissanFL
11
02-19-2015 11:08 AM
jakesurfin
Texas -OK -LA (Sales)
20
10-15-2012 09:06 PM
jakesurfin
07-19-2012 12:09 PM
