Will a car run without a battery? - Honda-Tech
Old 05-10-2005, 04:13 PM   #1
CRXDrew's Avatar
Default Will a car run without a battery?
Just wondering. Can a car after its started run without a battery. I had a bad battery/alternator and since then have replaced both. Just wondering if the battery was bad could the alternator sustain the car during highway driving?
CRXDrew is offline   Reply With Quote
Old 05-10-2005, 05:20 PM   #2
B16Civic93's Avatar
Default Re: Will a car run without a battery? (CRXDrew)
well if the alternator works and the car is running than yes it will keep running but only if the battery is able to hold a small charge, however if the battery will not hold a charge than it will not start up again. i would suggest just getting a new battery. if you had a magnito than it would stay running
B16Civic93 is offline   Reply With Quote
Old 05-10-2005, 05:40 PM   #3
eg6T's Avatar
Default Re: Will a car run without a battery? (B16Civic93)
if the battery dies,yea it will stay running but if it gets disconnected the car will shut off
eg6T is offline   Reply With Quote
Old 05-10-2005, 05:59 PM   #4
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
Default Re: Will a car run without a battery? (eg6T)
Quote:
Off my old school Prelude I removed the terminals completely off the battery. Still ran.
INVALID is offline   Reply With Quote
Old 05-10-2005, 07:31 PM   #5
eg6T's Avatar
Default Re: Will a car run without a battery? (INVALID)
Quote:
i was driving and my terminal came off and my car totally died and i had to pull over and reconnect it...
Old 05-10-2005, 07:51 PM   #6
Brian Hinson's Avatar
My battery cable came loose one day while I was driving, and I didnt realize it until I got back in my car to leave, and it wouldnt crank
Brian Hinson is offline   Reply With Quote
Old 05-10-2005, 10:16 PM   #7
Tmack's Avatar
if you pull the battery while the car is running it will run depending on the style of circuit the car has. The bad side of this is when you reconnect the battry the surge of power will blow the regulator.
Tmack is offline   Reply With Quote
Old 05-11-2005, 02:24 AM   #8
CRXDrew's Avatar
Yea... I had this happen: I was running an AZ alternator and a small hawker battery for the longest. Car would never start up if it sat for a day or two and the battery would lose charge.
replaced the battery... went ok for a while... problems reappeared
replaced the alt... then new battery wouldn't hold charge
(figured messed up alternator killed the first battery and now the second one aswell)
replaced the alternator and warranteed the battery...
Now everything seems ok, stupid Autozone alternators. Oh well.
GSR in EG problem carlosd68 Honda Civic / Del Sol (1992 - 2000) 26 09-18-2012 07:00 PM
is my alternator dead? xcoregage Honda Accord (1990 - 2002) 18 12-13-2009 09:30 PM
alternator probs ... xcoregage Tech / Misc 1 12-10-2009 09:19 PM
12V vs. 16V on sfwd? choiboiracing Drag Racing 5 02-08-2005 08:11 AM
battery light - searched mjrage Honda Civic / Del Sol (1992 - 2000) 8 06-24-2004 07:05 PM
Tags
04, accord, acura, alternator, battery, car, cars, honda, moter, newer, removed, run, running, started, stay, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
