Axle problem? Stabilizer bar? Don't know
Ok when I drive my car and tapped on the gas i hear a big banging noise its only on the driver side so i parked my car and check to see if anything is wrong and i don't see anything. All i know is that when my car is parked and i grab the driver side wheel it sways back and forth like the cv joint is busted (which it isn't cause its brand new). But on the passenger side it won't budge. Also when i press on the brake the whole tire seems to jerk as well. It can't be a suspension problem cause i don't see why it will ever do that.
need all help i can get thanks.
Re: Axle problem? Stabilizer bar? Don't know (97exracer)
On the top of your lowr control arm for your car there is a stabilizer bar and bushing. Most likely the washer and nut which holds this in place is not there anymore or loose. Crawl under the car and check it out.
