where exactly is the 5mm cam holes
redoing my timing belt, I want to know where exactly is this 5mm hole to hold the cam gears from moving...question is in plain sight, or do i have to remove more the cam brackets to access them...where are they??? picuture would be nice too
Re: where exactly is the 5mm cam holes (RoyFokker)
You should see holes on your cam plates, two long silver pieces that run the length of your cams. It's right next to your the cam pulleys and you should be able drop a allen key wrench down in the hole. Also if you put the cam to TDC and look under the cam plates then you should see the holes on the cam.
