wiring harness help !!
Old 12-29-2003, 01:58 AM
mrDFWmechanic's Avatar
Default wiring harness help !!
so i have a JDM b16a2 SIRII block with a b16a USDM SI head .... what wiring harness do i get ?? the jdm or usdm version or are they the same
Old 12-29-2003, 04:36 AM
Jeff C's Avatar
Default Re: wiring harness help !! (civryder02)
I'd say use the usdm one cause the head is where most of the sensors are, but they are probably the same anyway.
What ecu are you going to be using?
Modified by Jeff C at 12:47 PM 12/29/2003
Old 12-29-2003, 08:39 AM
mattssi's Avatar
Unless your car is rhd, don't get a jdm harness! What kind of car is it, most of the time you use the harness that was on the motor in the car!
Old 12-29-2003, 01:37 PM
ok so i just need a regular b16a harness ... and i plan to use a p28 ecu
silentdaredevil2
07-06-2005 05:50 PM
mpxs20
06-20-2005 10:34 AM
wizzards581
10-21-2003 09:55 AM
eddiecut
08-17-2003 07:39 PM
humtake
05-08-2003 06:01 PM
Quick Reply: wiring harness help !!
