whats the difference between drop compression
Old 10-27-2004, 10:16 PM
SpeedMachine's Avatar
Default whats the difference between drop compression
whats the difference between dropping the compression through a headgasket and dropping the compression through pistons?
Old 10-28-2004, 12:15 AM
granteeton's Avatar
pistons are the safer way to do it. if you increase your head gasket thickness, the you run a risk of coolant leaking if you go to far, and with pistons, the shape of the top changes to change the compression ratio.
jmeyer99
10-24-2010 10:32 AM
JAMSiR
05-26-2010 08:24 AM
I_know
12-21-2002 07:07 AM
Quick Reply: whats the difference between drop compression
