What in the world is wrong with my clutch?
When I'm first starting my car in the morning, or after I've had the clutch clamp hard (like taking off quickly amd going up through the gears), when I push the clutch in, it will fall to the floor and not come back up. When this happens, the engagement point is like, 1" from the floor. It still grips fine, but unless it's warmed up, or I pump the clutch a few times after shifting hard, it's unresponsive. Could this be the master/slave cylinder going, or could I just have bubbles in the line? Thanks in advance.
Re: What in the world is wrong with my clutch? (GSRGuy17)
lol nice sig...
sorry cant give any help, my clutch is unstable too- but i think its because i didnt bleed it yet...
Re: What in the world is wrong with my clutch? (3rdGteg)
check the slave cylinder, its more than likely the problem. if that does work, bleed the system and get some new fluid. but more than likely the slave cylinder bolt is loose or air is in the system
Re: What in the world is wrong with my clutch? (CART fan)
3rdgteg - sounds like a bad slave cyl or master cyl.
gsrguy 17 - you need to bleed the clutch line. (like everyone else has said)
[Modified by KAMiN, 12:04 AM 11/3/2002]
Re: What in the world is wrong with my clutch? (KAMiN)
3rdgteg - sounds like a bad slave cyl or master cyl.[Modified by KAMiN, 12:04 AM 11/3/2002]
My master cyl. has no leaks anywhere and fluid in the reservoir is still full, can it still be the master cyl.??
