What does a broken axle sound like? - Honda-Tech
Old 09-07-2003, 05:44 PM   #1
drvfast's Avatar
Default What does a broken axle sound like?
my car had very bad wheel hop and i now hear a clicking noise when im driving it only does it when i shift or when im of the gas. what could it be axle or something else. thanks its an b16 with an y21 tranny by the way the noise is coming from the driver side
drvfast is offline   Reply With Quote
Old 09-07-2003, 06:51 PM   #2
ejprimo's Avatar
Default Re: What does a broken axle sound like? (drvfast)
does it "click" when you make hard turns?
ejprimo is offline   Reply With Quote
Old 09-08-2003, 01:29 PM   #3
TomO's Avatar
if you broke an axle your car wouldn't move, so It's not a broken axle then. But you might have destroyed the CV shafts from having bad wheel hop. Or you toasted a ball joint, either upper or lower. Grab the wheel that the noise comes from with your hands at the 9 and 3 position and pull one hand towards you and the other away, alternatly. If the wheel feels solid, your tie rod end is good. Now put your hands at the 12 position of the wheel and shake in and out, if you feel the wheel move, then you have a bad upper or lower ball joint. HTH
TomO is offline   Reply With Quote
Old 09-08-2003, 05:57 PM   #4
Cynical 1's Avatar
Default Re: What does a broken axle sound like? (SonicGSR98)
Quote:
Yup. Most likely a CV joint. $$$
Cynical 1 is offline   Reply With Quote
Old 09-08-2003, 06:18 PM   #5
jaysonx's Avatar
Clicking is usually a bad CV joint. Verify this and goto Napa to buy a new axle. There are lots of good howto's on this forum.
New axle @ napa = $70.00 w/ core (give or take).
jaysonx is offline   Reply With Quote
Old 09-10-2003, 01:18 PM   #6
Banned
Sounds like you need to change the CV boot, if it only makes a clicking sound.
BluePrintmfg.com is offline   Reply With Quote
Old 09-10-2003, 01:31 PM   #7
redlinegsr's Avatar
Default Re: What does a broken axle sound like? (11sec.ALL MOTOR)
yea regrease and change the boots cheap fix if thats what it is
redlinegsr is offline   Reply With Quote
Old 09-10-2003, 06:12 PM   #8
LT1killa's Avatar
Default Re: What does a broken axle sound like? (redlinegsr)
Mine did the same til I greased it
LT1killa is offline   Reply With Quote
Bad Wheel Bearing? Axle? Weird Noises. pcorad Acura RSX DC5 & Honda Civic EP3 22 09-01-2014 10:23 AM
Growling noise - CV joint? tobytigger Honda Accord (1990 - 2002) 2 01-11-2014 02:41 PM
Clunking noise when making hard turns BrayzieEF9 Honda CRX / EF Civic (1988 - 1991) 20 02-13-2010 06:51 PM
what does a clicking noise from my axel when it turns mean? preludexl Honda Civic (2001 - 2005) 3 10-05-2008 12:23 PM
could bad motor mounts cause clicking noise? MeanGreenEG9 Tech / Misc 15 12-16-2002 08:20 AM
Tags
axle, axles, ball, boot, broke, broken, car, cv, joint, like, make, noise, shaking, sound, sounds
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
