What does a bad input shaft bearing sound like?
Old 09-25-2016, 06:59 AM
masospaghetti's Avatar
Default What does a bad input shaft bearing sound like?
I have an intermittent faint chirping / squeak coming from the transmission bellhousing area. Using a stethoscope it's by far the loudest on the clutch release arm. If I put any pressure on the clutch pedal the noise stops.
Sound like my ISB going bad? Will I get fair warning before it explodes?
92 Accord w/ H23A1 and M2S4 transmission. Thanks
Old 09-25-2016, 03:35 PM
holmesnmanny's Avatar
Default Re: What does a bad input shaft bearing sound like?
take the two 10mm bolts off the slave cylinder and put some grease on the ball tip of the piston and see if the sound goes away
Old 09-25-2016, 04:47 PM
Hmm so maybe the pivot point is squeaking when there's no pressure? Makes sense, good idea. I'll try that.
jdsande3
09-15-2013 11:57 PM
g0tgot
07-02-2012 12:04 PM
2000-em1
Transmission & Drivetrain
12-29-2011 05:52 AM
reyrey2006
08-05-2008 07:55 PM
Ek9Max
03-15-2005 07:19 PM
Quick Reply: What does a bad input shaft bearing sound like?
