What does "spin a bearing" mean?
Old 02-08-2003, 10:45 AM
  #26
owen_the_soyboy's Avatar
Default Re: What does "spin a bearing" mean? (Wes V)
wicked post
Old 11-19-2008, 08:10 AM
  #27
sik_tC's Avatar
correct me if im wrong, but the 10 psi rule only works with a 5w20 oil, I THINK.
I KNOW
when im gunning 4 grand to 3,500 on the interstate in my car its right on 60 but that IS with 10w30 oil
i think the different weights of the oil changes the PSI it runs at.
not 100% sure just read it somewhere.
Old 11-19-2008, 07:54 PM
  #28
string's Avatar
Originally Posted by bigTom
no they dont spin with the crank... the bearings will also stay seated with the in the cap/block or the cap/rod... when u spin a bearing what it essentially does it get thinner... now u have a gap so everytime the crank rotates u now hear a "knocking noise" which is lets say if u spin a rod bearing... its the rod actually bouncing up and down on the crank as it spins
Of course what you have said happens in many cases, but the term "spinning a bearing" obviously comes from the extreme case where the bearing literally spins with the crank; damaging not only the bearings. Wearing down a bearing is simply that, wearing a bearing.
Old 11-19-2008, 11:20 PM
  #29
mcmotors's Avatar
you are correct, but the term "spun bearing" is used so loosley... Someone refering to a "spun bearing" could have excessive bearing wear and what probably should be refered to as a "rod knock", but I don't ASSume anything.
Wes V had the best and most proper answer.
On a ligher note, this thread is funny!
Old 10-27-2011, 08:43 AM
  #30
kyral's Avatar
Is there any extra precautions one can take when rebuilding a motor to help prevent this?
Old 10-27-2011, 09:58 AM
  #31
flush_EJ1's Avatar
I figured this thread was worthless without pics of said spun bearings.
Here is a couple from a 3SGTE engine before I built it. This one in particular did spin in the connecting rod. The piece at the bottom is half a bearing. These are the only pieces I have. I just threw the rest away this weekend but it was carnage. Every single bearing was either smashed or broken. the crank on #4 was also worn away to .03"
Here are few engine building tips to help prevent a spun bearing.
  • Cleanliness. Build the engine in as clean an area as possible. There is a reason factory/high end engines are built in clean rooms.
  • Build the engine slightly loose and pay attention to torque specs.
  • Dont damage the crank when installing the pistons/rods.
  • Always replace the water and oil pump.
Old 10-28-2011, 06:45 PM
  #32
B20vREX-LD's Avatar
It's when the bearing around your crank spins and typically makes a knocking noise.
Old 10-30-2011, 02:32 PM
  #33
Got traction's Avatar
spun rod bearings eventually lead to a window in the motor
Old 11-02-2011, 04:53 PM
  #34
TheToaster's Avatar
Isn't It called a babbitt bearing?
soon2bdropped
12-14-2010 03:42 PM
jbrokos307
13
10-21-2009 05:51 AM
Baron55
10-02-2006 07:09 PM
jdmcivicferio
03-16-2003 06:54 AM
Quick Reply: What does "spin a bearing" mean?
