Weird ticking?
Old 06-04-2003, 11:08 PM
whatcivic's Avatar
Default Weird ticking?
So my car makes this ticking noise when idling. It's not there all the time. It ticks for a few seconds then it stops for a bit then it ticks again. It seems to be coming from the engine. I did a valve adjustment today and it still does it. Anyone know what it could be?
Old 06-05-2003, 12:04 AM
poison's Avatar
Default Re: Weird ticking? (whatcivic)
What set up and what mods?
Try to listen around the engine bay to see where the ticking is coming from as well.
Old 06-05-2003, 05:37 AM
whatcivic's Avatar
Default Re: Weird ticking? (poison)
B16a with i/h/e - seems to be coming fron the front of the engine
Old 06-05-2003, 09:01 AM
JDMCivicHatch93's Avatar
check your oil level
Old 06-05-2003, 09:54 AM
Stripped Honda's Avatar
Default Re: Weird ticking? (JDMCivicHatch93)
adjust your valves that can caue the noise...
Old 06-05-2003, 10:36 AM
whatcivic's Avatar
Default Re: Weird ticking? (Stripped Honda)
I just did the valve adjustment yesterday
Old 06-05-2003, 11:34 AM
beevo.'s Avatar
Sounds like Lost Motion Assemblies. They (8) sit under the vtec rocker arms and keep them from ticking when vtec is not engaged.
Old 06-05-2003, 12:22 PM
poison's Avatar
Default Re: (GoldenDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like Lost Motion Assemblies. They (8) sit under the vtec rocker arms and keep them from ticking when vtec is not engaged.</TD></TR></TABLE>
This also sounds like it. Also make sure the cam gear bolt is torque'd properly.
Old 06-05-2003, 12:58 PM
97lsturbo's Avatar
Default Re: (poison)
Check out you distruibuter that may be it because i know mine does it!
Old 06-05-2003, 02:10 PM
skunked's Avatar
I agree with Golden, sounds like the LMA's
Old 06-05-2003, 06:11 PM
whatcivic's Avatar
Default Re: Weird ticking? (skunked)
So do they basically need replacing? (Sorry I'm kinda of a noob to this engine stuff..)
Old 06-05-2003, 06:14 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatcivic &raquo;</TD></TR><TR><TD CLASS="quote">So do they basically need replacing? (Sorry I'm kinda of a noob to this engine stuff..)</TD></TR></TABLE>
yes. they aren't very expensive. LMA hold the VTEC cam lobe when you are not in VTEC so it's not 'flopping' around basically.
Old 06-05-2003, 08:14 PM
whatcivic's Avatar
How do I find out which ones are bad? Or if it even is them that are causing the noise?
Old 06-06-2003, 07:13 AM
beevo.'s Avatar
Put your motor at TDC for cylinder 1, take off your valve cover and push down on the vtec rocker arms above cylinder 1. They should spring back up with no problem. Then TDC for cyl. 2 and check those, TDC 3, etc. Also if the ticking quits when vtec is engaged it's probably the LMA's. If you buy new ones you mght as well go ahead and by ITR LMA's.
sohctodohc
01-20-2008 06:28 PM
mortificationrock
11
12-05-2007 08:26 AM
ej2civic
10-02-2005 09:43 AM
94LSVtecTeg
08-10-2003 08:06 PM
bananacruzier
02-16-2002 10:06 AM
Quick Reply: Weird ticking?
