VTEC bolt sheared flush with head
So, I'm one of the lucky few who has seemed to accomplish this great task!
I already purchased an extractor kit and I became even more lucky as the extractor snapped inside the bolt.
Does anyone have some tips or insight into my situation?
How much meat is around the top left VTEC solenoid bolt, can I drill it out much bigger and tap it?
Thank you
Thank you
Re: VTEC bolt sheared flush with head
Hahah it gets better.
I drank two beers and attempted to remove myself from the situation for a while. Went back at it and drilled into some fresh metal, attempted to tap it and the tap broke...China is really ******* me over today.
I'm about to JBweld it on...
longest project ever
Location: on the south side of dixie, 1986 Accord Hatch
you were screwed as soon as you bought the extractor, NEVER use those things, some machinist who was pissed at the world invented them as his revenge. the extractor is almost as hard as a tap, and once a tap breaks you are done. all they do is break and they are nearly impossible to remove, if someone brought me that part with a busted off extractor and tap, I would tell them get a new part
Well, most of the bolt is out, however, I feel as though I've taken a lot of the metal around the hole with it.
I'm going to hope there is enough meat left to insert a helicoil or timecert.
Grind out all of the messed up.material, tig weld the are back up. Drill and tap a new hole, grind surounding excess weld flat.
DO IT ON ALL FOURS
We have, but it comes down to the right tools for the right job. From the pictures it was a botch job at best. Left-handed drill bits and some heat go a long way. Now me and the mad scientist are going to have to... oh wait, never mind, wrong part.
Does anyone have any experience with aluminum fillers? I've seen several that advertise that they can be tapped etc.
Thank you
Thank you
Sugar Shane
22
10-17-2012 07:59 PM
shadowstylz
09-16-2003 10:20 AM
