TPS mounting position on aftermarket throttle body?!
Old 09-08-2014, 06:18 PM
Cincykemo's Avatar
Default TPS mounting position on aftermarket throttle body?!
I'm using a OEM tps on an aftermarket throttle body. The tps when mounted isn't at the spec voltage. I trimmed the tips and rigged it on the aftermarket throttle body and it works fine but it is in need of constant adjusment. Is there a adjustable tps or adapter plate for the OEM tps I need to buy?
Old 09-09-2014, 10:03 PM
holmesnmanny's Avatar
Default Re: TPS mounting position on aftermarket throttle body?!
There shouldn't be any need to trim anything. You simply mount the tps and turn it to get it to .45 closed, then tighten it down and recheck. As long as it's at .45 closed you're done.
Old 09-10-2014, 01:06 PM
Cincykemo's Avatar
I've been setting it at 5.1-4.8v depending on where I can get it to stay. If you mount it at the stock location it is no where close. That's why I was wondering if there might be a aftermarket tps with an adjustable mount
Old 09-10-2014, 01:08 PM
Cincykemo's Avatar
.51-.48 I mean
Old 09-10-2014, 04:16 PM
anywhere from .45-.50 will do fine
If you cant get it in that range its probably not in the two black tabs ... look more closely to how it lines up
Xtream_V
05-30-2011 06:41 AM
turboef90
03-23-2009 10:07 AM
VTEC_Du_Ma_Mai
07-17-2007 06:22 PM
Cpt Ben
04-05-2007 07:18 PM
Quick Reply: TPS mounting position on aftermarket throttle body?!
