torque specs?
I just didn't think it would work that way, since when you Plastigage your mains, you only tighten them down to half of what the torque will be, and it gives you the clearances; these clearances don't change when you fully torque down the mains, so I assumed the same would be true w/ the cam caps.
Mad Scientist
Re: (1700anddroping)
the 6x1.0mm bolts=7.2lb-ft
8x1.25=20lb-ft
And no the bore dont change when you torque them down....so tq them down looser makes.....no difference
Unless you put them like at 5lb-ft
8x1.25=20lb-ft
first of no one said anything about bore.tq yours down to spec and then do another motor,run them say 1-2k miles and look at the diff. then tell me if it don't make a diff.
are you saying that for the hole motor???
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping »</TD></TR><TR><TD CLASS="quote">
are you saying that for the hole motor???</TD></TR></TABLE>
?? what are we talking about?
how does it mak a difference then?
and you are saying that you torque the rod bolts looser?
no your implying,that no matter if you tighten or loosen them it won't make a diff. and i ask you to do that to a rod and get back to me.
i was just simply telling the guy that i run my cam caps a little loose to avoid wear on the cams and caps.it works for me.
now as far as the gestures go.we won't go there.
