TIMING PLEASE HELP!!! B18Ls/vtec
Old 08-14-2009, 04:47 PM
KC95egLS/Vtec's Avatar
Default TIMING PLEASE HELP!!! B18Ls/vtec
ok here is the story ... I make a left turn slowly. runs fine lalala. go to second.. give it gas and POP! POP! POP! POP! Black smoke in the mirror not accelerating... try to give it gas again same thing back fire city and black smoke.... pull into gas station, turn it off try to start it turns over fine but just back fires.... will not run.. everyone I talk to says the timing belt prolly jumped a tooth. So we try to move the belt a tooth get it to change a tooth now can't get the belt to completly tighten back up????..... how do I get it to tighten back up..and does it really sound like I jumped a tooth on timing belt???!?!?!
Old 08-14-2009, 05:47 PM
Jdmsoles's Avatar
Location: Dodgin Cops all Round Ana-Crime to Orange & Sd
Default Re: TIMING PLEASE HELP!!! B18Ls/vtec
easy way to find out, instead of trying to move the belt, why dont try using a timing gun, its 10x easier then moving teeth in advance or retard way, did you check the belt tensioner which is what keeps the belt nice and tight it is in between cam gears and crank shaft pulley. GL man!:thumbups:
Old 08-14-2009, 05:50 PM
rehaf's Avatar
For starters you don't want to just go randomly move the timing belt a tooth or so in either direction, make sure the timing marks line up.
dleccord
04-13-2020 08:03 AM
delsolboi
03-13-2013 11:57 AM
aaaabbbb
10-05-2004 03:02 PM
made in JAPAN
02-06-2003 07:30 AM
Quick Reply: TIMING PLEASE HELP!!! B18Ls/vtec
