Timing belt tension
Old 08-19-2012, 01:45 PM
Boyle.R's Avatar
Default Timing belt tension
What's the best way to determine if you have enough tension on timing belt?
Old 08-19-2012, 02:58 PM
a1320addict's Avatar
Default Re: Timing belt tension
A Gates 99107 Tension Gauge is useful.
Generally, 1/2" of deflection is acceptable. If you followed the correct sequence in putting your belt on, you don't have anything to worry about.
B/D/H/F
1) Set timing, tighten tensioner bolt.
2) Loosen tensioner bolt 180.
3) Rotate crank pulley counter clockwise to give you a (3) tooth offset in between your cams.
4) Tighten tensioner bolt to 40 ft/lb.
Old 08-19-2012, 04:45 PM
Boyle.R's Avatar
Yes I followed sequence in manual but my block and head have been milled so deck height is lower, won't this effect the tension on belt?
Old 08-19-2012, 06:36 PM
How much was taken off of each?
Theoretically yes, but you won't have it be an issue unless we are talking about a drastic amount off each.
Old 08-19-2012, 09:24 PM
slowcivic2k's Avatar
Depends on the thickness of the headgasket. Some people use a thicker gasket to compensate for resurfacing. I would prefer this on a stocker, as it is the cheaper option.
Any time you remove material from the head or block you should degree the engine and use an adjustable cam gear to advance the cam back to stock. Reducing the distance between the cam and crank results in belt slack, which retards cam timing. This cannot be fixed on the tension side without mechanically compensating for the slack.
Old 08-20-2012, 12:39 AM
Boyle.R's Avatar
There is about .0030" taken off between head and block. I'm fitting skunk cams so they will be dialled in.
j87w
08-15-2005 12:07 AM
SpoolinEK
12-17-2003 05:39 PM
InTeGrA B18b1
08-20-2003 07:57 AM
Silver_Rex
05-03-2003 09:38 PM
devonic
03-05-2003 09:33 AM
Quick Reply: Timing belt tension
