symptons of bad fuel filter/fuel pump?
I am having hesitation on the feeway driving at 4-5k rpm. It is only under light throttle, full throttle there is no problem.
I am wondering if it could be a bad fuel filter or fuel pump.
what signs are there to look for?
Re: symptons of bad fuel filter/fuel pump? (Bob-DC2)
If the old fuel filter is really old then I would change it anyway.Your probably detonating and don't even know if.And use 93 octane at least.
Dan
[Modified by vtechatch, 7:41 PM 2/27/2003]
Dan
I had a poor flowing fuel filter, but it was only apparent when when first jumping on the throttle. It would hesitate for a second or 2 and then accelerate like normal. What your have doesn't sound like the fuel filter, but the pump i'm not sure about.
I'd guess it would be worse at wide-open throttle, when its using the most gas & needs the highest pressure. Rig up a fuel pressure gauge so you can watch it while driving. See what it does as you accelerate.
pjr710
04-03-2010 05:59 PM
crnimacak
04-21-2006 10:11 PM
The_In_Kid
05-15-2002 12:33 PM
