Symptoms when timing belt jumps teeth? - Honda-Tech
Old 03-19-2003, 11:48 PM   #1
M-EJ1's Avatar
Default Symptoms when timing belt jumps teeth?
Ok, my car's been running really crappy lately and I can't figure out why. Here are the symptoms
1. Car runs really pitch black rich... if I rev it up in my driveway I get a big black streak behind my exhaust
2. Random CEL 43 codes, "Fuel Delivery System Malfunction"
3. Car is noticeably sluggish, and has no power above about 4000... it starts detonating soon thereafter.
5. Car dies randomly (may be a seperate electrical problem, but I'm not sure, the ECU may be getting completely confused)
6. And the clincher... I checked my timing a while back and it looked as though it was advanced into the stratosphere... way past the last white mark, I'm not sure how to gauge the numbers for sure, but if the red mark is 16 I would estimate it was around 20-22 degrees. I pulled it back to about 15 and now the car idles like crap, surges up and down and it sounds almost like it's misfiring.
So what's the diagnosis? Did I slip some teeth on the timing belt? I haven't had a chance to jack it up and check TDC on the pulley and cam gear, but I will be doing that tomorrow.
[EDIT]: Also, just for good measure... I'm running the Greddy SOHC turbo kit on a D16Z6, with DSM 450's and VAFC hack for fuel management. I haven't ever been able to get the hack running right, but it may be for this very reason.
[Modified by M-EJ1, 11:56 PM 3/19/2003]
M-EJ1 is offline   Reply With Quote
Old 03-20-2003, 08:55 AM   #2
tilt's Avatar
Default Re: Symptoms when timing belt jumps teeth? (M-EJ1)
well the lack of power when you rev would be a sign of a slipped belt, but im not sure about the black smoke.
tilt is offline   Reply With Quote
Old 03-20-2003, 10:12 AM   #3
Rhetoric's Avatar
Default Re: Symptoms when timing belt jumps teeth? (tilt)
If it is a slip tooth, take off the belt. Line up to tdc, also you can take off the crank pulley and line up the gear to the block, just to make sure everything is lined up.
Running a skip tooth may bend the valves, which can cause rough idles.
Rhetoric is offline   Reply With Quote
Old 03-20-2003, 11:40 AM   #4
dfoxengr's Avatar
if you jump enough teeth, car wont start
dfoxengr is offline   Reply With Quote
Bluebox and VAFC for minor adjustments? M-EJ1 Forced Induction 8 08-16-2003 01:43 PM
VAFC Hack... does it modify the ECU's closed/open loop settings? M-EJ1 Forced Induction 5 03-06-2003 10:59 PM
VAFC Hack guys... CEL 43 at partial throttle, cruising? M-EJ1 Forced Induction 7 03-03-2003 07:35 PM
VAFC hack- safe settings for D16 @ 6psi? M-EJ1 Forced Induction 4 02-26-2003 03:51 PM
Issue with ignition or clutch switch maybe? M-EJ1 Honda Civic / Del Sol (1992 - 2000) 4 12-15-2002 07:24 PM
Tags
belt, car, honda, jump, jumping, lack, power, slip, slipped, slipping, symptom, symptoms, teeth, timing, tooth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
