Stripped Engine Mount Bolt.....HELP - Honda-Tech
Old 07-04-2003, 08:46 PM   #1
xEGxB18Cx's Avatar
Default Stripped Engine Mount Bolt.....HELP
i over torqued the 17mm bolt that holds in the driver sider motor mount and it stripped the threads on the mut thats welded into the frame of the car (1992 Civic Hatch).......the bolt is now being held in place by only about 25% of the threads that are left on the nut........the rest of the nut is smooth i need to know if this is safe enought to hold the motor in, and if it isnt what can i do
xEGxB18Cx is offline   Reply With Quote
Old 07-04-2003, 08:59 PM   #2
Default Re: Stripped Engine Mount Bolt.....HELP (xEGxB18Cx)
God bless ..I've never seen that or heard about that happen ..You must have put like 300 lbs of tq on that biyatch!
DEVIN22CBR is offline   Reply With Quote
Old 07-05-2003, 12:42 AM   #3
blah13's Avatar
Default Re: Stripped Engine Mount Bolt.....HELP (BALL BAG)
If anything thread another nut on the remaining part of the bolt, throw some threadlock on and some vice grips to hold it while you torque the bolt, should hold.
blah13 is offline   Reply With Quote
Old 07-05-2003, 04:27 PM   #4
timesert is you friend
TREVER is offline   Reply With Quote
Old 07-05-2003, 06:42 PM   #5
Quote:
drill the nut off
go to the hardware store, buy a nut and washer
problem solved if your worried about it
irev210 is offline   Reply With Quote
Tags
1000rr, bolt, bolts, civic, driver, engine, honda, hondatech, motor, mount, mounts, nut, stripped, thread, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
