steering wheel shake at idle with soid mounts
i just installed hasport street mounts on my integra and steering wheel shakes bad at idle.
i have to pull it very slightly either direction right before the ps system engages. and it stops rattling.
i didn't have steering shakes on my other car with same mounts but it doesn't have power steering.
only does it at idle and was ok with stock mounts.
i see a lot of threads about it but haven't found if theres a solution for it or not
Re: steering wheel shake at idle with soid mounts
Vibration will take the path of least restriction. So urethane mounts will always cause vibrations in new places. Steering wheel, dashboard, bumpers are common ones. You can sometimes lessen it by loosening the mount to frame bolts and the re-tightening in case something was preloaded or tweaked during install
Did that no effect. Im gonna go under and see if anything is loose or blown out.
I really hope innovative start marking them now because thats really should have been done since the begining.
Its like honda injectors nobody knows wtf they are. Just like stock fpr.they all look same to me
Herbie
31
05-13-2015 06:34 PM
jacksonww
10-26-2008 03:49 AM
alwaysoverkill
12-06-2006 08:45 AM
