sputtering at low rpms...???
91 teg ls has about 130k miles and going. car sputters at low rpm on slow acceleration. what could it be? it has new plug wires, plugs, rotor, cap what can it be? on cold start the tack bounces up and down 3k to 1k 3k to 1k what gives??? i need help thanks
Re: sputtering at low rpms...??? (SPEED123)
Mine was throwing more than 1 code. The main one I remember was
Code #43 - Fuel System, but the problem turned out to be my O2 Sensor Signal. It was grounding out, because of my voltmeter setup. ECU ran in closed loop between 2800 - 4000 rpm. After 4000 rpm the engine would run fine.
Sound familar?
91-integra
01-28-2020 10:36 AM
cilvia
11
04-02-2008 06:00 PM
