Spark Plugs are white --> what is my engine doing?? why? - Honda-Tech
Old 10-20-2005, 02:55 PM   #1
92integraVTECgsr's Avatar
Default Spark Plugs are white --> what is my engine doing?? why?
ok.. here is a pic of my spark plugs 4-3-2-1
the 4th one is more yellowish.
1, 2, & 3 are all white.
I am burning a little coolant over a month or so of time. would that be the cause of the 4th spark plug being yellow?
and why are the other 3 all white? why is my engine running hot?
I am going to have my timing checked and possible a leak down test.
any suggestions/help???
oh ya. 92 integra gsr b17a1
92integraVTECgsr is offline   Reply With Quote
Old 10-20-2005, 07:34 PM   #2
RTFM
those look perfectly nomral for a light load or idle plug reading.
v4lu3s is offline   Reply With Quote
Old 10-20-2005, 09:37 PM   #3
.Ry
.Ry's Avatar
Default Re: (v4lu3s)
Quote:
There is no sign of pinging or detonation so I would say your fine. I dont think that variation of color is coolant, how do you know your burning it?
.Ry is offline   Reply With Quote
Old 10-20-2005, 09:57 PM   #4
Default Re: (turner7205)
because over a period of time i loose coolant, and i am not leaking it.
the pic does not show it that good, but the 3 are completely WHITE.
the engine is stock. with a AEM CAI.
Old 10-21-2005, 05:08 AM   #5
RTFM
to read plugs you need to do a full throttle pull, and immediately turn the engine off, put it in neutral and pull over.
if you drive normally, or idle, hondas will run lean, whichi s how they are supposed to run. that means that you WILL pull plugs out and they will be white like yours.
what makes you think you are burning coolant? Personally i would say if you have very slight amounts of coolant missing it is beause a pinhole leak in a hose, that is FAR more likely than burning it. Or it could jsut be evaporating out of the coolant overflow specially if you live somepalce very hot.
Old 10-21-2005, 08:52 AM   #6
amckee's Avatar
Default Re: Spark Plugs are white --> what is my engine doing?? why? (92integraVTECgsr)
When coolant burns, it leaves white,chunky deposits on the plugs. Yours just look lean. #4 looks like it may be missing sometimes. Could also be white from high combustion temp. Have you checked all the small coolant lines around the intake? Small coolant leaks dont necessarily hit your driveway. Alot of times the leak only occurs at driving RPM when the pump pressure is high enough to squirt the coolant out. It can blow out on the road or evaporate on a hot engine block or exhaust. As long as you don't run too low on coolant, leaks don't explain your hot engine temp. You need to check your air flow(fans) and water flow through radiator and block.
amckee is offline   Reply With Quote
Old 10-24-2005, 10:08 AM   #7
Mad Scientist
mmuller's Avatar
Default Re: Spark Plugs are white --> what is my engine doing?? why? (amckee)
are those lil chunks of Al. on #4 spark plug?
mmuller is offline   Reply With Quote
Old 10-24-2005, 05:59 PM   #8
Tippyman's Avatar
ya man, if those are little droplets of aluminum on your #4 ground strap u got some serious detonation prob's! i'd look at it before starting your motor again!
Tippyman is offline   Reply With Quote
Read my plugs? One totally different colour to rest. (PICS) zombo Tech / Misc 2 05-03-2011 07:27 PM
Misfire in cylinder no.2, on a jdm 98spec ITR EGgoJDM All Motor / Naturally Aspirated 18 01-07-2009 09:13 PM
spark plugs? white_db8 Acura Integra 10 07-25-2007 05:34 PM
Spark Plugs are white --> what is my engine doing?? why? 92integraVTECgsr Acura Integra 18 10-25-2005 09:16 AM
Maybe a Simple Question but Plugs are weird Turbo LS Tech / Misc 1 12-20-2001 01:02 PM
Tags
arewhite, buring, burning, coolant, ground, honda, hot, im, plug, plugs, show, spark, sparkplugs, tech, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
