which spark plug wire is #1 need to adjust timing
i need to know which spark plug wire is the #1 spark plug wire, need to adjust my timing with the timing gun.
Re: which spark plug wire is #1 need to adjust timing (b16crx000)
#1 cyl is furthest from the distributor and closest to the t-belt. #1 also has the longest spark plug wire. HTH
thanks guy's . and do yo think having incorrect timing would cause a car to miss in the higher rpm's? because im trying to fiure out this issing problem and i've already changed the plugs,fuel filter,cap,rotor, and if timing isn't it them im goona try a fuel pump because i don't think the factory crx hf pump pumps enough for the b16
Jkim81
11
10-25-2008 05:04 PM
px_R
05-24-2006 12:27 PM
