Smoke coming from dipstick!!
Old 08-04-2002, 09:41 PM
shermanyang's Avatar
Default Smoke coming from dipstick!!
okay, i tried starting my newly built motor today again, and i totally forgot to put the dipstick back in after checking my oil. i went to start it up and all of the sudden i see smoke just gushing out of that little hole where the dipstick was suppose to be. the car didn't start and i don't know what's wrong?!? anyone ever have this problem?
Old 08-04-2002, 09:53 PM
mailforjon's Avatar
Default Re: Smoke coming from dipstick!! (shermanyang)
got oil in the pan? i know a kid who forgot to replace the oil cap on the block itself and oil and sputtered out all over his engine bay. make sure you got some oil in there.
Old 08-04-2002, 11:59 PM
C-speed's Avatar
Default Re: Smoke coming from dipstick!! (mailforjon)
If smoke is coming out of the oil dipstick hole, it usually means one of two things.
1. the compression rings are toast and you are getting bad blow by
2. your motor is blown
Do a compression test.
Old 08-05-2002, 12:01 AM
poison's Avatar
Default Re: Smoke coming from dipstick!! (G3-TEG)
very well said
compression test says alot
Old 08-05-2002, 12:36 PM
Default Re: Smoke coming from dipstick!! (poison)
that's what i thought as well! damn...i'm using sorry *** total seal rings too. anyway, if i have low compression or blow by with these rings, does that or will that cause my motor to not start?
Old 08-05-2002, 12:42 PM
C-speed's Avatar
Possibly.. if there is little or no compression.. no motor will run.
Old 08-05-2002, 01:53 PM
riceboy's Avatar
you say its a brand new freshly re-built motor never had any miles on it?
Old 08-05-2002, 05:11 PM
Default Re: Smoke coming from dipstick!! (riceboy)
yes it's brand new(basically). i just finished it on friday and started it up on saturday. it only ran for 2 sec. then died and i haven't been able to revive it yet. i'm gonna to a compression test tonight and see if that's the problem.
shotgun2224
Honda S2000
12
02-13-2009 11:38 PM
H22CD7
05-28-2007 07:48 AM
Jeff
04-18-2005 06:23 AM
peel17
02-01-2005 11:28 AM
itsJDMyo
10
08-26-2004 12:16 PM
Quick Reply: Smoke coming from dipstick!!
