RPM work. speed odometer doesn't. Why?
Old 11-03-2011, 08:43 PM
koumatae's Avatar
Default RPM work. speed odometer doesn't. Why?
my speed odometer work but works weirdly. the MPH is off about 10mph. so if i go 15 mph, speed odometer show 25mph. if i go 10 mph, speed odometer show 20mph. ect. how can i fix this? has anyone had this problem before.
Old 11-03-2011, 09:42 PM
DirtyDA9's Avatar
Default Re: RPM work. speed odometer doesn't. Why?
The tach works because the tach and speedo get their signals from two completely different places. Have you changed and gearing or drasticly changed tire/wheel size?
Old 11-04-2011, 12:46 AM
koumatae's Avatar
what i change was the whole cluster. i didnt change tire or wheel size. but what do you mean "changed and gearing"? i thought it would be "plug-n-play" but i guess not.
Old 11-04-2011, 04:32 AM
Resident Gearhead
BryanM.'s Avatar
What is the car? (year/make/model)
Which engine?
Is there a CEL? (check engine light)
Answer all of these questions for better help!
Old 11-04-2011, 11:18 AM
DirtyDA9's Avatar
I meant have you changed ANY gearing... What cluster did you swap in?
Old 11-04-2011, 12:55 PM
koumatae's Avatar
i have a 94 Integra RS 2 door (B18B1) with no check engine light on. i also did not change anything on tranny or motor. i bought the cluster from someone on craigslist. i knew it was from an ls/rs dc2 because it redline at 6900 rpm and look exactly like any other cluster from ls/rs dc2. i try to reset the car by pulling out the negative on battery but that didnt work. any suggestion what else i can try? thanks HT
Old 11-04-2011, 04:07 PM
DirtyDA9's Avatar
Originally Posted by mcvtec
I don't understand what gearing or tire size has to do with the tach not working.
Read the title again "RPM works, speedometer doesn't.", rpm (as in tach) works. He is asking why his speedo is off, not about a non functioning tach.
His tach DOES WORK, it's the speedo that's off by 10mph. Drastically changing tire size, or gearing affects it.
Old 11-05-2011, 07:00 AM
Resident Gearhead
BryanM.'s Avatar
My apologies, I somehow got very mixed up or mis-read.
I agree with what you are saying.
Old 11-05-2011, 09:44 AM
DirtyDA9's Avatar
Lol It's all good I figured you were, I was wondering why you kept saying tach haha
Old 11-05-2011, 10:42 AM
frankenghia's Avatar
did you have this problem before you changed the cluster?
Old 11-05-2011, 04:18 PM
koumatae's Avatar
the gas meter didnt work so thats why i put the new cluster in. before that, the speed odometer work normally but now since i put another cluster in, the speed odometer is off and gas work. thanks HT for all your help.
Adriano
Transmission & Drivetrain
07-11-2012 02:28 PM
91akira
03-06-2009 12:45 PM
dso
05-19-2005 05:14 PM
See Are Ex
12-06-2004 01:12 PM
integra-modder
11-05-2002 11:52 AM
Quick Reply: RPM work. speed odometer doesn't. Why?
