Should I ever grease the lugnuts?
Old 10-12-2002, 09:46 PM
LudemanDan's Avatar
Default Should I ever grease the lugnuts?
When I'm swapping back and forth between two sets of wheels, should I grease the lugnuts or just leave them dry?
Thanks,
Dan
Old 10-12-2002, 10:27 PM
Aphrodavid's Avatar
Default Re: Should I ever grease the lugnuts? (LudemanDan)
dry, that is unless you want the lugnuts to come off.....
Old 10-12-2002, 10:45 PM
New User
BreakStuff's Avatar
Default Re: Should I ever grease the lugnuts? (DX-R)
I grease lugnuts....
Its the lugs that haven't been removed in a long period of time that create all the problems.. this is especially true with alloy rims due to that super-bonding affect of aluminum oxide...
If you swap rims around frequently, then I see no harm in leaving them dry... But there is no harm in lubing as well and I just prefer greasing them...
Old 10-12-2002, 11:40 PM
ls_vtec_b18a1's Avatar
Default Re: Should I ever grease the lugnuts? (BreakStuff)
dry dry dry
Old 10-12-2002, 11:53 PM
New User
BreakStuff's Avatar
Default Re: Should I ever grease the lugnuts? (ls_vtec_b18a1)
can someone explain the "dry" theory to me?...
I'm not saying it's right or wrong, I would just like to understand why this is the case..
Old 10-13-2002, 01:49 AM
B18C-EJ1
Guest
Posts: n/a
Not grease, anti-seize compound.
Works great!
Old 10-13-2002, 02:02 AM
ULTRA911's Avatar
Default Re: Should I ever grease the lugnuts? (B18C-EJ1)
why does it have to be dry? i spray wd40 and grease them up when the nuts don't want to go in, otherwise, i leave them dry.
Old 10-13-2002, 06:34 AM
non-VTEC's Avatar
Works great!
Old 10-13-2002, 07:25 AM
Chiovnidca's Avatar
Dry. Torque to 80 lb/ft.
Old 10-13-2002, 07:27 AM
IN VTEC's Avatar
Default Re: Should I ever grease the lugnuts? (ULTRA911)
WD-40 or silicone spray. A dab of anti-seize if they're really gnarly.
Old 10-13-2002, 12:30 PM
EleanoR's Avatar
Default Re: Should I ever grease the lugnuts? (IN VTEC)
Use a dab of antiseize and apply to each stud before putting the new wheel back on. This helps ensure a proper torque when torquing the wheels. Also makes it easier for swapping wheels when you take the lug nuts on and off they wont get misthreaded and what not.
Old 10-13-2002, 01:58 PM
jweller's Avatar
Works great!
ditto
Old 10-13-2002, 03:42 PM
vtec.dc2's Avatar
Default Re: Should I ever grease the lugnuts? (Chiovnidca)
Torque to 80 lb/ft.
all that needed.. my wheels come of at least every 3000 miles.. so no problems there
Old 10-13-2002, 05:35 PM
El Veterano de Sur Califas
mannyman's Avatar
Default Re: Should I ever grease the lugnuts? (vtec.dc2)
i work at a tire store...and we use grease. Works great!!!
aWeimaraner
Northeast (Sales)
07-23-2010 05:18 PM
djteggy99
11-19-2008 06:16 PM
dshiromoto
11-12-2008 05:28 PM
cris[J(D)M]B17
03-04-2008 01:17 PM
spirit R
05-03-2004 03:54 AM
Quick Reply: Should I ever grease the lugnuts?
