S2000 Evap operational questions
To make a long story short, I'm interested in having an operational EVAP system (in that it will vent fuel tank pressure and vapor), but without all the self-testing and diagnostic that normally occurs.
To this end, I'm curious as to which sensors/valves/solenoids are merely for TESTING and which are actually operationally imperative to digesting fuel vapors through the engine.
Everything in bold is using Honda's nomenclature.
Evap Canister Purge Valve - This valve is electronically operated, and normally closed. This is in the engine compartment and as far as I can gather, the only "evap" component not in the rear of the vehicle. When commanded by the PCM under certain conditions (coolant temp above 149* F for instance), will open to allow the fuel vapors stored in the EVAP canister to be pulled via vacuum through the intake to be burned off. This is controlled via PCM pin A6 and it says that it's "duty controlled" via PCM
* The purge valve will for sure be required.
Evap Two Way Valve - From what I can gather, this valve is purely mechanical (no electronic control). Can anybody confirm? When the vapor pressure in the fuel tank is higher than a certain value, the valve opens and feeds fuel vapor to be stored in the EVAP canister.
* This valve will be required, just cannot confirm if it's purely mechanical or if the PCM controls it at all with feedback from the fuel tank pressure sensor
Fuel Tank Vapor Control Valve - Is this valve also purely mechanical? This valve specifically relates to refueling. It's supposed to open with the pressure in the fuel tank, and also feeds fuel vapor to the EVAP canister.
* It seems like this valve will also be required, especially to aid in refueling. Again, just cannot determine if it's purely mechanical or if it also relies on feedback from the fuel tank pressure sensor
Evap Canister Vent Shut Valve - I cannot find much info on this valve. Generic web searches suggest that for most manufacturers, this valve is normally open. Honda FSM says this valve has battery voltage via PCM A4 (lt grn/wht wire) at ignition switch on. The other wire in the vent shut valve's connector is black/yellow, originating at fuse 6, which is hot in on.
What role does the Fuel Pressure Sensor play in overall Evap operation? When searching for detailed information on it, I cannot find much on it. I see it's a 3 pin connector.
Please only reply if you're familiar with evap systems or can contribute to the thread. I don't want to hear about how you ripped yours out and "everything is fine".
Thanks in advance to anyone that can help me out with this
- I don't understand this....how can it have power on both sides of the connector for this valve? One directly from the fuse box on blk/yellow wire, and the other from PCM pin A4.
- Does this mean that this valve is normally open? If so, under what conditions would it close? Does it close only for diagnostic self leak testing?
- What does this thing do?
- Is it required for Evap function or is it just for testing itself?
- I found that with the ignition switch on and fuel fill cap open, you should see about 2.5v @ PCM A29. Light green wire on FPS
- Looking at the diagram, it appears that the Green wire on the FPS splices into the green/yellow wire at the TPS and then goes to PCM C18, which also goes to green on the air pump current sensor.
- yellow/blue from FPS merges with air pump wiring, with VSS, and with TPS and originates at PCM C28
Re: S2000 Evap operational questions
I know it's been a year since you posted, but did you ever get answers to the questions you asked about S2000 EVAP controls?
I can provide one answer for you about voltage readings. The solenoid valve you mention in the post are controlled by the ECM sourcing ground to the circuit. This means that the ECM simply switched ground on and off on the output to actuate the valve while fused 12V was maintained on the opposite side of the circuit. On the valve terminals, with the valve in it's shelf state (not actuated) a volt meter will read 12V on each side because the meter is simply reading straight to the 12V source on one side and the same 12V through the coil on the other with no ground sourced by the ECM. If the computer was telling the valve to actuate, it would read ground on the that side at the valve terminals and the same maintained 12V on the opposite side.
Hope that clarifies. I am attempting an engine swap currently and am working through alternative methods to control the factory EVAP system with the OEM ECM removed from the car. I will post my progress as applicable.
Hello there .... no I never got much info so I didn’t even attempt to wire it in.
surprisingly I get no fuel smells or gas cap problems even in the texas summers, so honestly I never really thought much else about the evap once I got the car running.
gabrielsousa
15
06-21-2016 09:38 AM
