ROLL THE FENDERS
ROLL THE FENDERS
I low my car and she look like this / \ so i hook her up with camber kit after i properly adjusted, i started running in to problem with my tires rubbing the inside of the fenders. i just wonder is anybody here have experince with roll the fenders with the bat ? and how it work after u done it. is it recomend to do it or don't even try it it will mess up you fenders and a paint ?
Re: ROLL THE FENDERS (sohc00)
i rolled mine with a big hammer
all you do is stick the small end inbetween the tire and fender and slowly roll/wiggle it around until you get a smooth even bend throught the inside lip of the fender
i used a dremmel to cut some of it and painted the open metal(rear). The fronts I just left it alone where it would rub on the inner plastic liner. I wish honda fenders are made the same as the VWs
msinsky14
04-16-2006 02:12 PM
