riding on bumpstops - Honda-Tech
riding on bumpstops
Old 04-30-2004, 03:32 PM   #1
deviant1's Avatar
Default riding on bumpstops
my car is lowered on ground control coilover and illuminas. i have 16" rims and there is no fender gap on all four corners. my rears are not resting on the bumpstops but my front is. anyone know how to get the front of the car off the bumpstops and still have no fender gap? and why would my rear not be resting on the bumpstops like the front?
deviant1 is offline   Reply With Quote
Old 04-30-2004, 03:39 PM   #2
_BEN_'s Avatar
Default Re: riding on bumpstops (deviant1)
cut the bump stops.
When I nstalled tein s-tech springs on my '92 si The instruction sheet said I had to cut 1.4" off the fronts and .8" off the rears.
_BEN_ is offline   Reply With Quote
Old 04-30-2004, 07:28 PM   #3
deviant1's Avatar
Default Re: riding on bumpstops (_BEN_)
they are cut. as of now they are cut in half if i remember correctly. its been a while. some people suggested i cut them so they are 1 inch long. would that help?
Old 04-30-2004, 07:34 PM   #4
Ground Control has some front shock mounts that offset the top of the shock upwards. I forget how far it moves the shock, but it should get you some travel back.
Mohudsolo is offline   Reply With Quote
Old 04-30-2004, 07:51 PM   #5
get bigger wheels
C4wrx is offline   Reply With Quote
Old 05-01-2004, 02:56 PM   #6
deviant1's Avatar
Default Re: riding on bumpstops (h22eg)
my car rides like absolute crap now. i finally got a chance to hit the freeway. OMG. dips make the car go crazy. im think about just throwing on some h&r race springs on my illuminas instead now.
Old 05-01-2004, 03:27 PM   #7
7thGear's Avatar
there is such as a thing as being TOO LOW you know...
read this... if you have time
http://forums.vwvortex.com/zerothread?id=621342
7thGear is offline   Reply With Quote
Old 05-01-2004, 05:08 PM   #8
deviant1's Avatar
Default Re: riding on bumpstops (7thGear)
i dont think im too low. im only low enough to eliminate the fender/wheel gap. thats not too bad. im not even tucking tire.
Old 05-01-2004, 05:19 PM   #9
7thGear's Avatar
if your A arm is higher than parallel your too low ( for handling anyway)
Old 05-01-2004, 06:12 PM   #10
Quote:
what size wheels do you have?
Old 05-01-2004, 06:23 PM   #11
deviant1's Avatar
16 inch 205 45 16
Old 05-01-2004, 10:43 PM   #12
Sliced Beard's Avatar
you should cut your bumpstop roughly in half
you can also get some yop hats that give you a bit more suspension travel to make your shocks more effective
Sliced Beard is offline   Reply With Quote
Tags
14, acura, bump, bumpstop, bumpstops, coilover, cut, front, honda, hr, riding, stops, tech, tein, tl, wrx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
