replacing crank oil seals - easier way?
Old 11-03-2002, 06:01 AM
serious's Avatar
Default replacing crank oil seals - easier way?
my mechanic was telling me how they can replace the crank oil seals withoil dropping the oil pan by using special picks to pull the seal out. has anyone done this on their own? is there an easier way i can change the seals? if it comes down to having to pull drop the pan and crank, i'm just gonna take it to my mechanic and let him do it.
Old 11-03-2002, 07:19 AM
fixhondas's Avatar
Default Re: replacing crank oil seals - easier way? (serious)
No need to pull the pan or the crank. The seals come out by prying with a pick or a screwdriver. You have to remove the timing belt to do the front seal and the trans has to be removed to do the rear seal.
Old 11-03-2002, 07:11 PM
serious's Avatar
Default Re: replacing crank oil seals - easier way? (fixhondas)
the engine is out of the car with the tranny and timing belt off. i guess what i'm asking is if this is something i can do myself, and if it is, what i need to do it? directions on how would be really cool.
[Modified by serious, 11:12 PM 11/3/2002]
Old 11-03-2002, 07:49 PM
povcivic95's Avatar
easy way---take all the bolts out of the front case and there are 2 bolts u have to take out that are on the oil pan...just put the front case on like a vise and knock the old seal out with a flat screwdriver and a small hammer..put the new one in by centering it best you can..get a socket that fits around the seal nicely and tap her in gently..it will be in when it is flush with the case..good luck.
Old 11-04-2002, 05:18 AM
serious's Avatar
Default Re: replacing crank oil seals - easier way? (povcivic95)
this is for the tranny side oil seal, right? what about the oil pump side oil seal?
Honda-Tree
Honda CR-V & Element
04-16-2014 06:37 AM
rrmaron
12-04-2011 11:54 PM
oldskoolDA6
11-26-2007 02:17 PM
ludelvr
12-19-2003 11:01 AM
Quick Reply: replacing crank oil seals - easier way?
