Problem with reading ecu codes
Old 05-19-2005, 08:03 AM
themadscientist367's Avatar
Default Problem with reading ecu codes
I have a 1997 Civic Ex. My engine light has been on for a bit. Recently it will blink while I'm going up a hill with throttle about 75%. I also have a seal bad because I burn oil. I know that is alot of my problems. It is the stock engine so I am trying to get the best out of it until I can afford a swap. Anyway, I was doing the ECU trick with a piece of speaker wire to jump terminals. It gave me codes 73 and 74 a couple of times. It also gave me code 90. Any ideas on what the problem and how to fix it? Also how do I determine what P code it is throwing do I have to have a special device? Thanks in advance for anyone's help. I'm a newbie to this site... and just trying to get my car running right...
Later.......
Old 05-19-2005, 08:59 AM
EE_Chris's Avatar
Default Re: Problem with reading ecu codes (themadscientist367)
73 and 74 are misfire codes and that is why your CEL blinks at you - because you're misfiring.
90 is an EVAP code.
The P codes can only be read by a scantool.
How many miles on the car? What does the maintenance history look like? Did you do something recently and then these codes came on?
jesiaczek
01-26-2012 03:31 PM
freshvibes
02-27-2009 09:45 PM
Speed94
11-06-2006 06:35 PM
ThefirstPACT
22
01-11-2004 07:17 AM
Cozmo Kraemer
06-16-2003 12:54 PM
Quick Reply: Problem with reading ecu codes
