Removing check engine light/bulb from dash - Honda-Tech
Old 10-13-2003, 06:33 PM   #1
udm_motorsport's Avatar
Default Removing check engine light/bulb from dash
Hi
I recently did a ZC swap to my Civic Si 1990.
By doing this, the check engine light is always on, and i cannot pass emissions with it on.
I was told to remove the bulb, but i dunno where to start. Any ideas as to how i can get rid of the light?
Thanks
Franklin
udm_motorsport is offline   Reply With Quote
Old 10-13-2003, 08:29 PM   #2
Default Re: Removing check engine light/bulb from dash (to_carpediem)
reset ecu disconnect neg side wait 10-15 seconds reconnect should go out.
Rossifumi is offline   Reply With Quote
Old 10-13-2003, 08:31 PM   #3
The smog station checks the CEL for proper functionality. Notice it turns on for 5-8 seconds when you start the car . . .
It does that for a reson ;-)
jeff652 is offline   Reply With Quote
Old 10-13-2003, 09:26 PM   #4
Ever try to figure out what was wrong with it and, oh, say, fix it?
MrHeeltoe is offline   Reply With Quote
Old 10-14-2003, 05:39 AM   #5
Default Re: Removing check engine light/bulb from dash (MrHeeltoe)
Actually, reading alot of the ZC swaps, since we have to splice a couple of wires and rewire the distributor, they said the check engine light will be on all the time.
I reset the ecu, but that didnt work either. So i figured i'd just remove the bulb so i can get the car inspected.
Thanks
Franklin
Old 10-14-2003, 08:08 AM   #6
That is BS. I had two ZCs in Two different cars and never had a light or a problem.
Sounds like you need to fix some wiring or something.
Old 10-14-2003, 08:26 AM   #7
PhatOptimo's Avatar
What CODE is it flashing?
PhatOptimo is offline   Reply With Quote
Old 10-14-2003, 09:04 AM   #8
sleepyEK's Avatar
Default Re: Removing check engine light/bulb from dash (PhatOptimo)
yeah, i have never seen a cel on a zc swap. you wired some **** wrong. go through your wiring harness.
sleepyEK is offline   Reply With Quote
Old 10-14-2003, 09:21 AM   #9
wickedEFguy's Avatar
Quote:
BUMP, Again check your codes man
wickedEFguy is offline   Reply With Quote
Old 10-14-2003, 12:22 PM   #10
Katman's Avatar
Quote:
Originally Posted by to_carpediem
Hi
Thanks
Franklin
*shakes head*
why the hell would you wanna do that?!?
That's not gonna solve your problems in passing emissions at all.
Even though you'd remove the check light, your car is still going to be running in limp mode.
Find out what code is being thrown; report back so we can help.
Katman is offline   Reply With Quote
Old 10-14-2003, 12:57 PM   #11
1bad-eg's Avatar
FIX YOUR CEL
1bad-eg is offline   Reply With Quote
Old 10-14-2003, 01:01 PM   #12
Default Re: Removing check engine light/bulb from dash (1bad-eg)
OK, so how do i check the codes?
I'm very new to the civic and know not much.
I do have the integra ecu too.
Thanks
Franklin
Old 10-14-2003, 02:21 PM   #13
PhatOptimo's Avatar
http://www.c-speedracing.com/faq/06.php
You don't need a paper clip like it says. Skip that part. Out cars don't have that blue connector.Turn the key to the on position and count the ECU light flashes. The ECU is under the passenger footwell carpet.
The code list is here
http://tech.hybridgarage.com/tech/codes.html
can cluster bulbs affect cel beegeedee Honda Civic / Del Sol (1992 - 2000) 7 11-11-2012 09:01 AM
Check Engine Light Bulb Replacement Nathan_volcom Honda Civic / Del Sol (1992 - 2000) 5 06-10-2012 10:34 AM
1990 accord computer codes Rat Rod Honda Accord (1990 - 2002) 10 10-16-2010 01:47 PM
Coolant temp. sensor Dreamw3rkz Tech / Misc 2 09-29-2008 03:08 PM
Power steering / Check engine light Fomoco Acura Integra Type-R 3 05-01-2006 05:41 PM
Tags
1991, 1999, accord, bulb, cel, check, civic, disable, disconnect, engine, honda, light, remove, removing, si, smog
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
